Installing Nagiosxi behind the firewall
abhi
Post by abhi »
Hi There!
I had a couple of questions on installing nagiosxi behind the firewall:
- Is there a list of urls/ dependencies / packages/ repositories that I need to whitelist on the network for the Nagiosxi installation behind the firewall?
(Im using a system with RHEL 6.6)
- Is there a guide/ instruction set for installing Nagiosxi behinf the firewall?
Request you to kindly let me know.
Eagerly awaiting your reply,
Abhi
Re: Installing Nagiosxi behind the firewall
You might find some information in our offline install guide:
http://repo.nagios.com/
And in fact treating this as an offline install might even be easier, if you have a local mirror of the repos you can use.
