we are creating multi stack graphs using graph explorer and deploying them to dashboards. The only issue is that once deployed you can not change the scale of it. for example if I initially set it to 4h I can not zoom out to 24hours, I can only zoom in.
Is it possible to have a pulldown or check boxes on the actual graphs that allow you to change the scale ?
Thank you
Sanjay
Scaling multistack graphs
Re: Scaling multistack graphs
At this time it's not going to be possible, however I believe this is a great idea. I filed a feature request for this, ID #9538, which would allow you to modify the graphs already added to a dashboard.
We cosign! We would love this feature.
Also if you could apply a ServiceGroup to a graph... That would be even more than helpful.
I filed a feature request for this as well, ID #9543. It would be really cool to be able to see all graphs for a service group, or even assign it on just the multistacked graphs page for dashboards without the manual addition. Technically speaking, I believe it would also be a great use for service groups.mberkley wrote:We cosign! We would love this feature.
