Can I install Nagios XI as non-root user?
Hi, Can Nagios XI be installed as a non-root user? Thanks
Re: Can I install Nagios XI as non-root user?
Most of the scripts called by the fullinstall script need to be run as root/superuser. So, you can either install nagios as root or use "sudo".
