Check windows time is not listed as a service on nagios gui
Morello
Post by Morello »
Hi all,
I used the script below in order to add nagios windows clients ntp check.
https://exchange.nagios.org/directory/P ... 29/details
This script seems to be working okaywhen i check like this from nagios server:
[root@server~]# /usr/lib64/nagios/plugins/check_nrpe -H host -c check_windows_time
OK: Time is -00.5094249s from pool.ntp.org|'Offset'=0s;30;10;0
But i can not see check_time listed as a service on nagios server when i opened up the gui however i should be able to see it as listed services I can only see modules like checkdisk, currentload, check, checkservice, checkprocess etc these are all listed under modules and set to 1 in nsclient.ini file. Any ideas why i can not see the newly added script as a new service on nagios gui? Please see img attached for listed services... Thanks for any help or assistance. Regards, Utku
Here is my nsclient.ini file.
# If you want to fill this file with all avalible options run the following command:
#   nscp settings --generate --add-defaults --load-all
#   nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; Undocumented key
password = XXXXX
; Undocumented key
allowed hosts = 127.0.0.1,::1
[/settings/NRPE/server]
allow arguments = 1
allow nasty characters = 1
allowed hosts = 1.2.3.4
port = XXXX
use SSL = 1
; Undocumented key
verify mode = none
; Undocumented key
insecure = true
[/modules]
; Undocumented key
CheckExternalScripts = 1
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NRPEServer = 1
; check_windows_time
check_windows_time = check_windows_time.bat pool.ntp.org 30 10
Re: Check windows time is not listed as a service on nagios
You more than likely just need to create a service that is for the check_windows_time check.
For the check command, I believe it would just be -
   check_command        check_nrpe!check_windows_time
If that doesn't help please post the full configuration file which houses the other services.
Morello
Post by Morello »
You mean creating a service by configuring windows.cfg on nagios server?
I did not enable monitoring windows host on nagios server, i am just trying to add this check on all nsclient windows hosts like the other checks you have seen on the picture.
Can you help me out how to get my service shown on nagios server like the other services?
What configuration file you needed?
BR,
Morello
Post by Morello »
Never mind, i got this working... Just forgot to add the service on nagios server.
Many thanks...
Great to hear :) I'll be closing this thread now, but feel free to open another if you need anything in the future!
