Hi Team,
Memory usage monitoring for below scenario:
If the Tomcat process virtual memory use exceeds 120% of the allocated physical memory then; Send a WARN Alert (Email notifications only); and if the virtual memory use exceeds the 150% of the allocated physical memory; then Send a CRITICAL alert (Email notifications and Incident)
Could you please advise here to how we can monitor memory usage for single process?
Memory Usage Monitoring
Re: Memory Usage Monitoring
A quick search on our Exchange shows quite a few plugins for Tomcat - https://exchange.nagios.org/index.php?o ... ord=tomcat
Take a look at these, and find one that will work for your requirement.
