Performance counters with Nsclient++
mdsupersonic
Hi Support team,
unfortunately after locking the previous thread ,My service stopped working and return this error : ' Failed to poll counter: Web Service PdhAddCounter failed: c0000bb9: The specified counter could not be found.'
I don't know what exactly happened,everything was fine and suddenly it shows Unknow status with above error message.
Any help appreciated.
Re: Performance counters with Nsclient++
Doh! Did you make the change in the CCM, or the raw file?
Could you post the entire check_command for us to review?
One thing to note - if it just magically changed, after previously working, you may have multiple processes running. What is the full output of ps -ef?
mdsupersonic
check_nrpe!CheckCounter!-a "Counter:Web Service=\\Web Service(_Total)\\Total Get Requests" ShowAll MinWarn=500 MinCrit=256!!!!!!
This is the check command,I went and rewrite it and now is working.
Its weired
Its weired
Did you modify it in the Core Config Manager, or the raw file on the machine? If you edited the raw file, it'll get overwritten by the CCM every time you apply configuration.
mdsupersonic
Just modifying in CCM,but honestly I don't know what really happened
Do you believe in ghosts?mdsupersonic wrote:Just modifying in CCM,but honestly I don't know what really happened![]()
Hehe, I'm not sure either, but it sounds like things are working once again. It could have been a case of multiple processes as I mentioned above.
I'll leave this thread open for now since your last one was locked - let us know if it comes up again and we'll address it.
mdsupersonic
So far so good. I think If nothing happen in 2 hours you can close this thread.
Thank you again for your help.
You're welcome, we'll have begun our weekend by that time so we'll of course leave this thread open - please update it when appropriate - thanks.
mdsupersonic
Thank you again for your help.I think you can lock this thread and everything went right during weekend.
mdsupersonic
Thank you for your help.
Everything went well during weekend and I think we can lock this thread.
