Capactiy Planning
rs00469183
Capactiy Planning
Under Capacity planning I can see the options Observed ,Predicted ,Fit ,Warning & Critical so please let me know what is meant by fit ?
avandemore
Re: Capactiy Planning
Fit is the best fit linear line generally speaking, Predicted uses more complicated algorithms.
Previous Nagios employee
rs00469183
Could you please let me know how can i use this feature and how it is useful ?
It is the average / best fit for the line based on what the available data points are.
See this video for a further explanation - https://www.khanacademy.org/math/probab ... t-exercise
avandemore
The feature is included by default for any Capacity Planning graph. A best linear fit is simply a straight line through a plotted graph with the line as close to all points as possible. It's best used to predict static change.
