Nagios email notifications not working
kellyangell
Post by kellyangell »
nagios.cfg
(43.96 KiB) Downloaded 338 times
contacts.cfg
(551 Bytes) Downloaded 300 times
commands.cfg
(8.05 KiB) Downloaded 284 times
Hello
My email alerts are not working, can someone please check my configuration files, i have uploaded them. i have sent a test message from nagios so i know send mail is working, but i am not receiving notifications for critical and warnings. please can someone help me out :)
Cant wait to hear from you .
Re: Nagios email notifications not working
Could you please post your /usr/local/nagios/var/objects.cache file for us to look at? The ones you posted look fine, assuming general-contact has notification commands defined.
Also, please let us know the host / service and contact, that you're attempting to get notifications for so that we know what to compare it against.
kellyangell
Hello
i have got it working , so need need to do anything, one more thing is the mails i am receiving are blank and i would like it to contain the status information , is there something i need to change in these 2 entries , as it is a db query i am running i would like to see the output and comments in my email alerts.
hope to hear from you soon. kelly
command_name notify-host-by-email
command_line /usr/bin/mail "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/mail "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\n Additional Info:\n\n$SERVICEOUTPUT$\n$LONGSERVICEOUTPUT$ $NOTIFICATIONCOMMENT$\n" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
avandemore
Post by avandemore »
Here is some documentation for you: Standard Macros in Nagios
So your command definitions are correct. Is your host/service returning output? Can you post an example message?
Previous Nagios employee
Take a look at this - https://assets.nagios.com/downloads/nag ... olist.html
You could change your $HOSTOUTPUT$ to $LONGHOSTOUTPUT$ but, I'm not sure that will be the data you're after. For your services, you've already got $LONGSERVICEOUTPUT$ appended so I don't believe more information will be possible.
Could you show us what you're seeing in a current email, vs what you would like to see with screenshots?
kellyangell
hello
here is a screen shot of the email , there is no information its just the subject
thanks
email .tiff
email .tiff (75.92 KiB) Viewed 4594 times
avandemore
Can you do the following:
  1. backup /usr/local/nagios/etc/nagios.cfg
  2. edit /usr/local/nagios/etc/nagios.cfg to contain the values debug_level=256 and debug_verbosity=2, replacing the existing ones
  3. Restart Nagios Core
  4. Provoke an event which will trigger one of these emails
  5. Upload /usr/local/nagios/var/nagios.debug
  6. Wait for further instructions, if that is enough information I'll have you restore the original and restart again.
kellyangell
it won't allow me to upload a file with the .debug extension
Simply change the extension to .txt and it should be fine.
kellyangell
haha of course . its been a long day ! here is the file
nagios.rtf
(732.26 KiB) Downloaded 285 times
