Hi Guys,
I've been trying to get logserver installed on my Centos 7 system and due to a bit of HTTP issues I've messed up the original install. Can someone help me uninstall it so I can reinstall it correctly?
Nathan
Installation messed up
Re: Installation messed up
I would strongly recommend starting with a new clean minimal VM. It will save you an awful lot of time. If you need help migrating data, let us know and we can do a write-up.
nathanplatt
I'll love too, but this is a physical server and i can't just wipe it
nathanplatt
This is what i've tried so far
All i get is this when accessing the site;
http://192.168.1.200/nagioslogserver/#/dashboard
Error Could not contact Elasticsearch at http://192.168.1.200/nagioslogserver/api/backend. Please ensure that Elasticsearch is reachable from your system.
[root@support www]# nano config.js
[root@support www]# service httpd restart
Redirecting to /bin/systemctl restart httpd.service
[root@support www]# cd /tmp/
[root@support tmp]# ls
6MMMmAyvVD hsperfdata_root nagiosgraph-1.5.2 nagioslogserver-1.4.2.tar.gz systemd-private-23ff6cf437814afe91929d61bd8c7a7b-httpd.service-G1U5Sm
9sBnCyADjq huxzjANS6s nagiosgraph-1.5.2.tar.gz nagioslogserver-latest.tar.gz systemd-private-23ff6cf437814afe91929d61bd8c7a7b-ntpd.service-1rnMb9
hsperfdata_nagios jna--1053006215 nagioslogserver perfata.log
[root@support tmp]# cd nagioslogserver/
[root@support nagioslogserver]# ls
addnode CHANGELOG.txt get-pip.py install.log licenses nagioslogserver subcomponents
build_dev_tarball.py fullinstall installed.all libinstall.sh mibs sourceguardian upgrade
[root@support nagioslogserver]# rm installed.all
rm: remove regular empty file ‘installed.all’? y
[root@support nagioslogserver]# ./fullinstall
Nagios Log Server Installation
DATE: Fri 28 Oct 15:24:23 BST 2016
DISTRO INFO:
CentOS
7.2.1511
x86_64
Running 'setup_local_syslog'...
Redirecting to /bin/systemctl restart rsyslog.service
setup_local_syslog step completed OK
Running 'prereqs'...
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
* base: mirror.cov.ukservers.com
* epel: fr.mirror.babylon.network
* extras: mirror.cov.ukservers.com
* updates: mirror.sov.uk.goscomb.net
Package byacc-1.9.20130304-3.el7.x86_64 already installed and latest version
Package cairo-devel-1.14.2-1.el7.x86_64 already installed and latest version
Package gcc-4.8.5-4.el7.x86_64 already installed and latest version
Package glib2-devel-2.42.2-5.el7.x86_64 already installed and latest version
Package glibc-2.17-106.el7_2.8.x86_64 already installed and latest version
Package 1:java-1.7.0-openjdk-1.7.0.111-2.6.7.2.el7_2.x86_64 already installed and latest version
Package libxml2-devel-2.9.1-6.el7_2.3.x86_64 already installed and latest version
Package 1:make-3.82-21.el7.x86_64 already installed and latest version
Package 1:net-snmp-5.7.2-24.el7_2.1.x86_64 already installed and latest version
Package 1:net-snmp-utils-5.7.2-24.el7_2.1.x86_64 already installed and latest version
Package ntp-4.2.6p5-22.el7.centos.2.x86_64 already installed and latest version
Package 1:openssl-1.0.1e-51.el7_2.7.x86_64 already installed and latest version
Package patch-2.7.1-8.el7.x86_64 already installed and latest version
Package pango-devel-1.36.8-2.el7.x86_64 already installed and latest version
Package perl-ExtUtils-MakeMaker-6.68-3.el7.noarch already installed and latest version
Package php-5.4.16-36.3.el7_2.x86_64 already installed and latest version
Package php-cli-5.4.16-36.3.el7_2.x86_64 already installed and latest version
Package pyOpenSSL-0.13.1-3.el7.x86_64 already installed and latest version
Package sendmail-8.14.7-4.el7.x86_64 already installed and latest version
Package sudo-1.8.6p7-17.el7_2.x86_64 already installed and latest version
Package sysstat-10.1.5-7.el7.x86_64 already installed and latest version
Package unzip-6.0-15.el7.x86_64 already installed and latest version
Package zip-3.0-10.el7.x86_64 already installed and latest version
Package net-tools-2.0-0.17.20131004git.el7.x86_64 already installed and latest version
Package php-ldap-5.4.16-36.3.el7_2.x86_64 already installed and latest version
Nothing to do
28 Oct 15:24:37 ntpdate[19199]: adjust time server 158.43.128.33 offset 0.005723 sec
Requirement already up-to-date: pip in /usr/lib/python2.7/site-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): argparse in /usr/lib/python2.7/site-packages
Requirement already satisfied (use --upgrade to upgrade): jsonselect in /usr/lib/python2.7/site-packages
Requirement already satisfied (use --upgrade to upgrade): elasticsearch-curator==3.4.0 in /usr/lib/python2.7/site-packages
Requirement already satisfied (use --upgrade to upgrade): elasticsearch<2.1.0,>=1.8.0 in /usr/lib/python2.7/site-packages (from elasticsearch-curator==3.4.0)
Requirement already satisfied (use --upgrade to upgrade): click>=3.3 in /usr/lib/python2.7/site-packages (from elasticsearch-curator==3.4.0)
Requirement already satisfied (use --upgrade to upgrade): urllib3<2.0,>=1.8 in /usr/lib/python2.7/site-packages (from elasticsearch<2.1.0,>=1.8.0->elasticsearch-curator==3.4.0)
prereqs step completed OK
Running 'sourceguardian'...
Installing sourceguardian...
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.4.lin
Sourceguardian extension found for PHP version 5.4
Sourceguardian extension already in php.ini
sourceguardian step completed OK
Running 'timezone'...
sed: -e expression #1, char 57: unknown option to `s'
timezone step completed OK
Running 'nagioslogserver'...
chgrp: cannot access ‘/var/www/html/nagioslogserver/www/media’: No such file or directory
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'nagioslogserver'
[root@support nagioslogserver]# cd /var/www/html/nagioslogserver/
application html lsversion system
[root@support nagioslogserver]# rm -rf /var/www/html/nagioslogserver/*
[root@support nagioslogserver]# ls /var/www/html/
index.php nagioslogserver
[root@support html]# rm -rf nagioslogserver/
[root@support html]# ls
index.php
[root@support html]# cd /tmp
addnode CHANGELOG.txt get-pip.py installed.setup_local_syslog installed.timezone libinstall.sh mibs sourceguardian upgrade
build_dev_tarball.py fullinstall installed.prereqs installed.sourceguardian install.log licenses nagioslogserver subcomponents
DATE: Fri 28 Oct 15:39:01 BST 2016
DISTRO INFO:
CentOS
7.2.1511
x86_64
setup_local_syslog step already completed - skipping
prereqs step already completed - skipping
sourceguardian step already completed - skipping
timezone step already completed - skipping
Package php-common-5.4.16-36.3.el7_2.x86_64 already installed and latest version
Nothing to do
nagioslogserver step completed OK
Running 'backend'...
Installing Elasticsearch...
Elasticsearch installed OK
Installing Logstash...
Applying Nagios patches to Logstash...
Logstash installed OK
Installing Kibana...
Kibana installed OK
UUID file already exists
backend step completed OK
Running 'install_mibs'...
install_mibs step completed OK
Running 'sudoers'...
sudoers step completed OK
Running 'firewall'...
success
success
success
success
success
success
success
success
success
success
firewall step completed OK
Running 'selinux'...
selinux step completed OK
Running 'test_cluster_connection'...
test_cluster_connection step completed OK
Running 'daemons'...
Note: Forwarding request to 'systemctl enable ntpd.service'.
Created symlink from /etc/systemd/system/multi-user.target.wants/ntpd.service to /usr/lib/systemd/system/ntpd.service.
Note: Forwarding request to 'systemctl disable ntpd.service'.
Removed symlink /etc/systemd/system/multi-user.target.wants/ntpd.service.
Note: Forwarding request to 'systemctl enable httpd.service'.
Note: Forwarding request to 'systemctl disable httpd.service'.
Removed symlink /etc/systemd/system/multi-user.target.wants/httpd.service.
daemons step completed OK
Running 'webroot'...
Created symlink from /etc/systemd/system/multi-user.target.wants/httpd.service to /usr/lib/systemd/system/httpd.service.
webroot step completed OK
Nagios Log Server Installation Success!
You can finish the final setup steps for Nagios Log Server by visiting:
http:///nagioslogserver/
Try this to uninstall:
service logstash stop
service elasticsearch stop
yum erase httpd
rm -rf /usr/local/nagioslogserver
rm /etc/rc.d/init.d/elasticsearch
rm /etc/rc.d/init.d/logstash
rm /etc/rsyslog.d/nagioslogserver.conf
rm /etc/cron.d/nagioslogserver
pip uninstall elasticsearch-curator==3.4.0
service crond restart
Former Nagios Employee.
me.
me.
Thanks Smith!
I would make one alteration:
pip uninstall elasticsearch-curator==3.4.0Former Nagios employee
nathanplatt
Thanks guys, go ahead a and close the case.
nathanplatt
FYI, I really did mess-up centos! Ended up rebuilding the server from statch!
- Former Nagios Staff
Thanks Smith!
I'm going to go ahead and lock this up.
Reason: corrected Smith's name
