5.3.1 Offline install
ksafa
Post by ksafa »
Any idea on when 5.3.1 offline install package would be available in Nagios Repositories?
Re: 5.3.1 Offline install
Post by dwhitfield »
Not presently. 5.3.2 should be coming out soon. We might skip 5.3.1 as an offline. Do you want to keep this open for updates, or do you want us to go ahead and close this up?
Reason: presentably to presently.
ksafa
Post by ksafa »
You can close but by soon does that mean couple weeks? month?
For the record, 5.2.9 is pretty stable, and 5.3.0 has had a couple hiccups. Once they are worked through the new offline RPM's will be built. I suspect it to be 2-3 weeks.
ksafa wrote:by soon does that mean couple weeks? month?
Offline for 5.3.3 is out: http://repo.nagios.com/
