Use SNMP to get disk space from two oids and add them
vtadisina
Post by vtadisina »
I want to get memory available from two oids and add those memories and compare it with a threshold to give an alert. Is there a way where i can do this.
ssax
Dreams In Code
Re: Use SNMP to get disk space from two oids and add them
Post by ssax »
What type of system is it, we may have a plugin that already does what you're looking for.
If there isn't an already made plugin you would need to write your own to perform the queries and calculations.
https://assets.nagios.com/downloads/nag ... inapi.html
https://nagios-plugins.org/doc/guidelines.html
Let us know if you have any questions.
Thank you
vtadisina
Post by vtadisina »
It is a Linux system and I am using UCD-SNMP-MIB to get 2 memory statuses in kb and add them and compare against a threshold
Post by mcapra »
Can you share the OIDs you are referencing? I wrote a plugin that calculates disk space for a given mount using the UCD-SNMP-MIB table which might satisfy your use case:
https://github.com/mcapra/nagios-check_snmp_storage_ucd
vtadisina
Post by vtadisina »
These are the Oids that i need the status from.
UCD-SNMP-MIB::memAvailReal.0 =.1.3.6.1.4.1.2021.4.6.0
UCD-SNMP-MIB::memCached.0 = .1.3.6.1.4.1.2021.4.15.0
Post by mcapra »
This plugin appears to leverage those OIDs:
https://exchange.nagios.org/directory/P ... em/details
You might give that a shot. With the understanding that this is not a plugin officially maintained by Nagios, feel free to share any issues you encounter with the plugin.
