UNKNOWN when using WMI--failed to bind uuid
cwscribner
Post by cwscribner »
Hi all.
I switched all of my windows servers over to WMI monitoring. I thought I was all set but apparently not....Nagios is throwing this error for every service
UNKNOWN: Could not retrieve all required data. Failed to bind to uuid 4d9f4ab8-7d1c-11cf-861e-0020af6e7c57 - NT_STATUS_NET_WRITE_FAULT
With the exception of a few listed as "Plugin timeout". The u:p pair that's supposed to be used to access these is located in Active Directory and is a domain user so I should have access to all the servers. How do I fix these errors? Are there additional permissions needed at the Active Directory level?
yancy
Re: UNKNOWN when using WMI--failed to bind uuid
Post by yancy »
Hi cwscribner,
is the domain user a member of the administrators group? I would use wbemtest and try a wmi query to ensure you can connect in a windows environment.
for example,
start > run > wbemtest > connect
namespace = \\remotemachine\root\cimv2
username=<username of domain user>
password=<password>
if wbemtest can't connect, nagiosxi won't be able to monitor either.
-Yancy
cwscribner
SOLVEDSOLVEDSOLVEDSOLVEDSOLVEDSOLVEDSOLVEDSOLVEDSOLVED
The username needs the domain before the username. e.g. [domain]/\[user] mydomain/\Nagios Forward slash is needed for escaping the backslash.
Ex: ./check_wmi_plus.pl -H 192.168.1.23 -m checkcpuq -u domain/\Nagios -p password
OK - Average CPU Queue Length 0.0 (3 points with 1 sec delay gives values: 0, 0, 0)|'Avg CPU Queue Length'=0.0;
Post by Box293 »
This might be a good one to add to the FAQs
cwscribner
Box 293, I 100% agree. Such a simple solution that has sucked up weeks of time.
