parse log file with grok
DigNetwerk
Post by DigNetwerk »
i've got a log file with the following content:
2016-11-23 03:00:14.651 - 00000001;{00000000-0000-0000-0000-000000000000};Print Manager Started
2016-11-23 03:00:14.714 - 00000000;{00000000-0000-0000-0000-000000000000};Synchronization: APS information restored
When i try to parse these lines with grok, i always get a grokparse error, i've come up with the following filter to try to debug:
if [type] == "srvprintrp-momaps" {
grok {
match => [ "message", "%{TIMESTAMP_ISO8601} \- %{BASE10NUM}\;\{00000000\-0000\-0000\-0000\-000000000000\}\;%{GREEDYDATA:info1}" ]
add_tag => "grokked_srvprintrp1"
grok {
match => [ "message", "%{YEAR:Year}-%{GREEDYDATA:info2}" ]
add_tag => "grokked_srvprintrp2"
However, the first IF clause always fails,
when i use: match => [ "message", "%{GREEDYDATA:Data}" ]
everything 'works'
when i added the parse the year: match => [ "message", "%{YEAR:Year}-%{GREEDYDATA:Data}" ]
it would fail again.
I have no idea to debug this simple log further?
Re: parse log file with grok
Post by mcapra »
It's not entirely clear what you're trying to do with this grok filter. There are some syntax errors and consistency issues throughout.
If you can tell me how you would like to break this message down, I would be happy to assist with writing a grok filter for the use case.
WillemDH
Post by WillemDH »
He wants the logs parsed in a few fields. The logs come in as type "srvprintrp-momaps".
Maybe something like this?
grok {
match => [ "message", "%{TIMESTAMP_ISO8601:logtimestamp} \- %{BASE10NUM:logsequence}\;\{00000000\-0000\-0000\-0000\-000000000000\:logid}\;%{GREEDYDATA:logmessage}" ]
The weird thing is that the logs:
match in tools like http://grokconstructor.appspot.com/do/match
but we keep getting grokfailures.
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
Post by mcapra »
It's probably an issue with escaping.
I had luck with the following filter:
    grok {
        match => [ "message", "%{TIMESTAMP_ISO8601:logtimestamp} - %{BASE10NUM:logsequence};\{(?<logid>[0-9]{8}-[0-9]{4}-[0-9]{4}-[0-9]{4}-[0-9]{12})\};%{GREEDYDATA:logmessage}" ]
Which, using the following source message:
2016-11-23 03:00:14.651 - 00000001;{00000000-0000-0000-0000-000000000000};My test messsage: some other stuff [but also useful]
Produced the following event:
DigNetwerk
i'm now using the following grok filter, but still it shows up as 'failed':
    grok {
 grok {
      match => [ "message", "%{TIMESTAMP_ISO8601:logtimestamp} - %{GREEDYDATA:Data}" ]
I still can't understand why it would also fail on the second grok parse...
Some more info:
The input filter in naglog:
tcp {
    type => 'srvprintrp-momaps'
    port => 5612
    codec => json {
        charset => 'CP1252'
the nxlog config file: (Note, the logs are in Unicode)
<Input file2>
	Module im_file
	File "C:\Program Files (x86)\uniFLOW Remote Print Server\Data\MomAps_*.Log"
	ReadFromLast True
	SavePos True
	Exec        $message = $raw_event; to_json();
</Input>
<Output out2>
  Module      om_tcp
    Host        10.54.25.140
    Port        5612
	#Exec $hostname = hostname(); $raw_event = $Hostname + " " + $raw_event;
    Exec $raw_event = to_json();
</Output>
<Route 2>
	Path file2 => out2
</Route>
EDIT:
I have changed the nxlog to:
<Input file2>
	Module im_file
	Exec convert_fields("UTF-16LE","UTF-8"); if $raw_event == "" drop();
	ReadFromLast True
	SavePos True
</Input>
and it now parses the grok filter, but now i see in the fields SourceModuleName & SourceModuleType, some strange characters.
Post by mcapra »
The strange characters are probably a combination of your input rule:
tcp {
    port => 5612
    codec => json {
        charset => 'CP1252'
And your nxlog object definition:
<Input file2>
   Module im_file
   ReadFromLast True
   SavePos True
</Input>
The input rule for Nagios Log Server is expecting the message to be encoded in CP1252 (charset => 'CP1252'), but you are converting the fields to UTF-8 in your nxlog definition (convert_fields("UTF-16LE","UTF-8");). This likely confuses logstash since it is expecting CP1252 but receiving UTF-8.
