Nagios Server low disk space
computerone
Post by computerone »
Hi All,
My Nagios server is running out of space. Can you please let me know which log files I can delete from server.
C1
Re: Nagios Server low disk space
It is most likely files in your /var/log folder, but if you deployed from the default OVA, then you only have 7GB allocated. I would look at expanding the file system - https://assets.nagios.com/downloads/nag ... M-Disk.pdf
What is the full output of df -H?
