We seem to be having an issue with our Local Scheduled Backups.
I had them running Daily at 00:05 at Location /store/backups/nagiosxi/
I did a Test permissions which returned -> The directory exists and is writeable.
I purged all of the unzipped folders from the /store/backups/nagiosxi/ directory.
The /store/backups/nagiosxi has 388GB available to it.
I set a backup for 5 minutes into the future. The /usr/local/nagiosxi/var/components/scheduledbackups.log shows
01-12-2017 07:55:01 DEBUG: Running scheduled local backup ...
01-12-2017 07:55:01 INFO: Creating a local backup: nagiosxi.1484225701
01-12-2017 07:55:01 DEBUG: Sending create local backup command to CmdSubsystemCode: Select all
PROCESSED 0 COMMANDS
SSL connect error
tail: /usr/local/nagiosxi/var/cmdsubsys.log: file truncatedCode: Select all
# sestatus
SELinux status: disabled
# ls -la /usr/local/nagiosxi/scripts/backup_xi.sh
-rwxrwx--- 1 nagios nagios 5672 Dec 13 09:25 /usr/local/nagiosxi/scripts/backup_xi.sh
# echo $0
-bash
# awk -F':' '{print $1 " " $7}' /etc/passwd | grep root
root /bin/bash- Nagios XI Version : 5.3.3
nagios1 2.6.32-642.6.2.el6.x86_64 x86_64
Red Hat Enterprise Linux Server release 6.8 (Santiago)
Gnome is not installed
- Provides the ability to schedule full Nagios XI backups.
1.1.3 09/15/2016 Nagios Enterprises, LLC
