Warning: Duplicate definition found for command
Re: Warning: Duplicate definition found for command
Post by mcapra »
Can you share the actual file rather than the output of more? That command is adding lines to the output and throwing off the line count. Stuff like this:
--Plus--(73%)
Do you know if cgi.cfg was modified using a Windows based text editor of some sort? Or has it not been touched at all? I copy+pasted your cgi.cfg into my environment and couldn't reproduce the issues, which leads me to believe there may be some encoding problems.
FabienA
Post by FabienA »
Ha... I'm sorry i have capture the configuration file with putty..
I will retry the capture without the adding lines.
FabienA
Post by FabienA »
This is the cgi configuration without adding lines
Thanks !!
cfig.cfg
(12.82 KiB) Downloaded 236 times
The error may be in the nagios.cfg file so could you post that file here so we can view it?
/usr/local/nagios/etc/nagios.cfg
Also, can you run the following commands on the Nagios system and post the output?
dos2unix /usr/local/nagios/etc/cgi.cfg
/usr/local/nagios/bin/nagios -vv /usr/local/nagios/etc/nagios.cfg
