Performance graphs
piotr
Performance graphs
Post by piotr »
Is it possible to create a performance graphs based on a plugin added to nagios. For example i have connected a service test that checks load on servers. I used a plugin check_snmp_load.pl. Is it possible to used this plugin for statistics so I could see in the performance graphs bookmark the load of the host.
Thank you for the reply
tonyyarusso
Re: Performance graphs
Post by tonyyarusso »
It should be possible for most sorts of plugins, yes. You may need to write a configuration for PNP to know how to process the data.
PNP Documentation: http://docs.pnp4nagios.org/pnp-0.4/start
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
