Host Child and Parent relationship
raamardhani7
Post by raamardhani7 »
Hi Team,
Is there any way that we can create a Child and Parent relationship with Hosts especially for Network devices. Any such event correlation is possible, please update us. thanks.
Re: Host Child and Parent relationship
Post by mcapra »
You would need to modify that host in the Core Config Manager to create the parent->child relationship.
raamardhani7
mcapra wrote:You would need to modify that host in the Core Config Manager to create the parent->child relationship.
Hi Team,
Thanks for this info. I'll be looking into this.
Is there any document explaining this concept? If yes, please do share. I wanted to use this for network devices. Please advise. thanks.
Take a look at this link. I think this is what you are looking for.
https://assets.nagios.com/downloads/nag ... ility.html
raamardhani7
tgriep wrote:Take a look at this link. I think this is what you are looking for.
Thank you Tom for the update. we can close this thread. thanks again :)
