SNMP Traps
SNMP Traps
Can anybody help configuring the SNMP traps at nagios core?
- Former Nagios Staff
Re: SNMP Traps
Have you looked at https://assets.nagios.com/downloads/nag ... ptrap.html ? If so, where are you getting hung up?
Re: SNMP Traps
i tried using SNMPTT but with no success.
these are my definitions
but what shoyld be the configuration for snmp conf files?
GNU nano 2.0.9 File: test.cfg
host_name testcoreapp2
address 10.0.5.12
contacts nagiosadmin,systemadmin
max_check_attempts 5
check_interval 1
retry_interval 1
parents SMCSW
check_period 24x7
hostgroups KDS PHYSICAL SERVERS
statusmap_image rack-server.gd2
notification_interval 0
notification_options d,u,r,s
notification_period 24x7
name trap-service
register 0
is_volatile 1
check_command check-host-alive ;Used to reset the status to OK when 'Schedule an immediate check of this service' is selected
flap_detection_enabled 0 ; Flap detection is disabled
process_perf_data 0 ; Do not Process performance data
max_check_attempts 1
normal_check_interval 1
retry_check_interval 1
passive_checks_enabled 1
active_checks_enabled 0 ; Prevent active checks from occuring as we are only using passive checks
check_period none
notification_interval 31536000
notification_options w,u,c ; Notify on warning, unknown and critical
contact_groups admins
use trap-service
service_description Trap1
avandemore
Re: SNMP Traps
What do you mean no success? Do you see traps in the logs? If so, please post them and any other errors you see. Otherwise we have very little information to go on.
Previous Nagios employee
Re: SNMP Traps
Ok. i need help giving you the proper and more information.
Where are the logs stored? What logs do you mean?
Re: SNMP Traps
/usr/local/nagios/var/nagios.log is one log that could shed some light.
Also
Please post your snmptt.ini and snmptt.conf (probably in /etc/snmp/)
What version of Core are you using? Was it compiled from source or installed from distro repos? On what OS/version is nagios running? cat /etc/*-release may be of use.
Also
/var/log/snmptt/
/var/spool/snmptt
Re: SNMP Traps
See attachments
snmptt.ini- (25.71 KiB) Downloaded 437 times
snmptt.conf- (102.9 KiB) Downloaded 477 times
nagios.log- (209.18 KiB) Downloaded 453 times
Re: SNMP Traps
See attachments
snmpttunknown.log- (182.37 KiB) Downloaded 416 times
snmpttsystem.log- (27.14 KiB) Downloaded 438 times
snmptt.log- (432 Bytes) Downloaded 444 times
Re: SNMP Traps
I can only find reference to the error message you are getting from 2005 and 2006, so just for a sanity check, I am going to re-ask a couple of questions. What version of Core are you using? Was it compiled from source or installed from distro repos? On what OS/version is nagios running? cat /etc/*-release may be of use.
It's possible the device is just old, but I just want to be sure.
I'm seeing errors associated with DataBS2. It looks like a lot of things are working. Are any of your SNMP traps working? Is SNMP in general working?
Re: SNMP Traps
Centos 6.8 and Nagios Core 4.2.0 compiled form source.
Device is not too old.
I can poll anything with snmp from any device in my network. But when i try to set snmp traps i cant. I use the scripts i posted before and my snmp conf is that i attached to you but when i send a test trap nothing appears at nagios web interface.
