Trying to delete a host from Nagios XI
I go to the services and able to delete all the service except one (Ping).
When I try I get the error:
Object ID: 9 of table tbl_service:
Relation to Serviceescalations, entry: Network High - Dependent relationship
Object still has dependent relationships!Item was not deleted.
So I went into Service Escalations and looked at the Escalation "Network High" but the host does not exist in that list of hosts.
Suggestions?
Service Escalations node not there
avandemore
wspackaging
Re: Service Escalations node not there
Navigate to Configure -> Core Config Manager -> Config File Management -> Run a 'delete', 'write', and then a 'verify. This will clear up any 'ghost' files which it sounds like you may be experiencing.
If that doesn't work, can you please PM over a profile for us to review? (Admin -> System Profile -> Download Profile) This will allow us to see your definitions and what's being parsed.
wspackaging
The delete write verify resolved the issue.
-pete
-pete
Will do! Feel free to open a new thread in the future.
