I am new in Nagios XI and I am trying to install It on new Linux server but failed during to the below error:
[root@te1-nms-rv-ap01 nagiosxi]# ./fullinstall
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary
sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or
RedHat. Do NOT use this on a system that has been tasked with other purposes
or has an existing install of Nagios Core. To create such a clean install
you should have selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n]
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-repos'...
Configuring Repos...
package centos-release is not installed
ERROR: Please add the 'Optional' channel to your Red Hat systems subscriptions.
You can do so in the Redhat Network web interface or using the rhn-channel command.
or, install the yum-utils package and use the following command:
yum-config-manager --enable rhel-7-server-optional-rpms
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-repos'
I did the required command and the result was:
[root@te1-nms-rv-ap01 nagiosxi]# yum-config-manager --enable rhel-7-server-optional-rpms
Loaded plugins: product-id, rhnplugin
This system is receiving updates from RHN Classic or Red Hat Satellite.
Any support?
Regards,
Hani
Installation Failed
Re: Installation Failed
After enabling, did you attempt the full install again?
I don't have a RHEL subscription to verify with, but I believe you need to enable the optional packages at the satellite level since it's being managed through there. This may be relevant - https://access.redhat.com/documentation ... repos.html
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up or has the issue otherwise been resolved?
