Dash Board view for the windows ,linux esxi seperately
anish
Post by anish »
Hi ,
How to create a dashboard based on OS for example I need a separate dash board to view the logs getting collecting from Windows ,linux ,esxi hosts separately . How to view the entire host list which are sending the logs to the particular Nagios Log server .
Re: Dash Board view for the windows ,linux esxi seperately
Post by mcapra »
There's a few ways to go about it. Typically, people will break down their logs by "type", so you'd have a "windows" type, a "linux" type, an "esxi" type, etc. Then, they would apply a filter to their dashboard for that specific type of log.
You'd need to first be filtering your logs by the type of machine they are coming from though. Typically, an input rule with a dedicated port for each log type is the easiest way to go about that. Something like this:
tcp {
    type => 'windows'
    port => 4000
tcp {
    type => 'linux'
    port => 4001
tcp {
    type => 'esxi'
    port => 4002
Though don't do that directly because nxlog ships Windows eventlogs as JSON by default :)
