AIX Memory Utilization -- Lpar
raamardhani7
Post by raamardhani7 »
Hi Team,
I would need your help in getting the CPU utilization of lpar. as per the script, threshold for warning and critical will be different for server to server. So wanted to have this information in percentages. Is there a plugin that can help me get that information? Or attaching the script, could you please help me with this.
#!/bin/ksh93
# check_lpar_physc_cpu.sh
# This plugin checks LPAR Physical CPU usage
# Author: Bratislav STOJKOVIC
# E-mail:[email protected]
# Version: 0.1
# Last Modified: October 2013
PROGNAME=`basename $0`
PROGPATH=`echo $0 | sed -e 's,[\\/][^\\/][^\\/]*$,,'`
REVISION=`echo 'Revision: 0.1'`
. $PROGPATH/utils.sh
print_usage() {
        echo "Usage: $PROGNAME -w <warning_thr> -c <critical_thr>"
print_revision() {
        echo $PROGNAME $REVISION
        echo ""
        echo "This plugin checks LPAR Physical CPU usage"
        echo ""
        exit 0
if [ $# -eq 1 ] && ([ "$1" == "-h" ] || [ "$1" == "--help" ]); then
        print_usage
        exit $STATE_UNKNOWN
elif [ $# -lt 4 ]; then
        print_usage
        exit $STATE_UNKNOWN
fi
while test -n "$1"; do
case "$1" in
        --help)
                print_usage
                exit 0
        -h)
                print_usage
                exit 0
        -V)
                print_revision $PROGNAME $REVISION
                exit 0
        -w)
            WARNING=$2
            shift
        -c)
            CRITICAL=$2
            shift
            echo "Unknown argument: $1"
            print_usage
            exit $STATE_UNKNOWN
esac
shift
done
LPAR_PHYSC=``
/usr/bin/lparstat 1 1 | awk '{print $5}'| tail -1
if (( $LPAR_PHYSC > $CRITICAL )); then
   echo "CRITICAL: $LPAR_PHYSC processor cores are busy.|Cores=$LPAR_PHYSC;$WARNING;$CRITICAL"
   exit $STATE_CRITICAL
fi
if (( $LPAR_PHYSC > $WARNING )); then
   echo "WARNING: $LPAR_PHYSC processor cores are busy.|Cores=$LPAR_PHYSC;$WARNING;$CRITICAL"
   exit $LPAR_PHYSC
else
   echo "OK: $LPAR_PHYSC processor cores are busy.|Cores=$LPAR_PHYSC;$WARNING;$CRITICAL"
   exit $STATE_OK
fi
Re: AIX Memory Utilization -- Lpar
Post by mcapra »
Can you share what this script outputs currently? I'm not super familiar with kornshell, but it should be some simple math that needs to be done on $LPAR_PHYSC before it gets added as performance data.
raamardhani7
mcapra wrote:Can you share what this script outputs currently? I'm not super familiar with kornshell, but it should be some simple math that needs to be done on $LPAR_PHYSC before it gets added as performance data.
Hi Team,
Updated the details.
 ./check_lpar_cpu -w 80 -c 90
OK: 0.03 processor cores are busy.|Cores=0.03;80;90
./check_lpar_cpu -w 0.2 -c 03
OK: 0.02 processor cores are busy.|Cores=0.02;0.2;03
0.02
./check_lpar_cpu -w 0.001 -c 0.2
WARNING: 0.02 processor cores are busy.|Cores=0.02;0.001;0.2
smt=4
physc
0.01
Please advise.
Post by mcapra »
Around lines 52, 56, and 70, you could probably multiply these respective variables by 100:
52      WARNING=$2
56      CRITICAL=$2
70      #new line to multiply $LPAR_PHYSC
Or, if you wanted your thresholds to be whole-number percentages, you could just modify line 70. If you're interested in having us modify this plugin for you, please contact our sales department regarding custom development.
