For me it looks like a problem when a broker_module sends data "back" to nagios.
I base this on the following facts.
If I disable mod_gearman in nagios.cfg, everything works OK.
If I enable mod_gearman in nagios.cfg, but do not use it for host-/service-checks, everything works OK.
If I enable mod_gearman and use it for host-/service-checks it starts crashing.
Sadly, the only thing I can see in the nagios-log are:
Caught SIGSEGV, shutting down...
Caught SIGTERM, shutting down...
In the debug-log I do not see anything strange.
Here are my SW releases:
OS: RHEL 7.3
Nagios-Core 4.3.1 (build from source)
mod_gearman 3.0.1-1 (labs.consol.de)
gearmand 0.33-5 (labs.consol.de)
Running nagios under gdb I see the following when it crashes:
Program received signal SIGSEGV, Segmentation fault.
clear_custom_vars (vars=vars@entry=0x7ffffffed940) at ../common/macros.c:2851
2851 my_free(this_customvariablesmember->variable_name);
Missing separate debuginfos, use: debuginfo-install boost-system-1.53.0-26.el7.x86_64 gearmand-0.33-5.x86_64 glibc-2.17-157.el7_3.1.x86_64 libgcc-4.8.5-11.el7.x86_64 libstdc++-4.8.5-11.el7.x86_64 libuuid-2.23.2-33.el7.x86_64 sssd-client-1.14.0-43.el7_3.11.x86_64
(gdb) bt
#0 clear_custom_vars (vars=vars@entry=0x7ffffffed940) at ../common/macros.c:2851
#1 0x00005555555916bc in clear_contact_macros_r (mac=mac@entry=0x7ffffffed2e0) at ../common/macros.c:3001
#2 0x00005555555918b7 in clear_volatile_macros_r (mac=mac@entry=0x7ffffffed2e0) at ../common/macros.c:2870
#3 0x00007ffff64aaa9e in handle_svc_check (event_type=, data=0x7fffffffda30) at neb_module_nagios4/../neb_module/mod_gearman.c:851
#4 0x000055555556bb2f in neb_make_callbacks (callback_type=callback_type@entry=6, data=data@entry=0x7fffffffda30) at nebmods.c:529
#5 0x0000555555569f10 in broker_service_check (type=type@entry=704, flags=flags@entry=0, attr=attr@entry=0, svc=svc@entry=0x555555e97310, check_type=check_type@entry=0,
start_time=..., end_time=..., cmd=, latency=0, exectime=exectime@entry=0, timeout=timeout@entry=0, early_timeout=early_timeout@entry=0,
retcode=retcode@entry=0, cmdline=cmdline@entry=0x0, timestamp=timestamp@entry=0x0, cr=cr@entry=0x0) at broker.c:326
#6 0x000055555557172f in run_async_service_check (svc=svc@entry=0x555555e97310, check_options=check_options@entry=0, latency=latency@entry=0.0008800000068731606,
scheduled_check=scheduled_check@entry=1, reschedule_check=reschedule_check@entry=1, time_is_valid=time_is_valid@entry=0x7fffffffe29c,
preferred_time=preferred_time@entry=0x7fffffffe2a8) at checks.c:199
#7 0x0000555555571cb1 in run_scheduled_service_check (svc=svc@entry=0x555555e97310, check_options=0, latency=latency@entry=0.0008800000068731606) at checks.c:90
#8 0x0000555555587adb in handle_timed_event (event=event@entry=0x555555e8fc20) at events.c:1171
#9 0x0000555555588623 in event_execution_loop () at events.c:1110
#10 0x0000555555568a56 in main (argc=, argv=) at nagios.c:814Has anything changed with the NEB interface between 4.2.4 and 4.3.1?This looks like it may be a Core bug. I was able to replicate with pre-built and compiled from source ModGearman modules.
Any suggestions on what could be wrong (I know you do not "support" 3:d party modules, but let us not start finger pointing, please).
If you need more debugging info, I would be glad to help.
Regards,
