Deleted Hosts & Services Still Showing in Views
bvinisky
Post by bvinisky »
I have several hosts that have been deleted and no longer show up in the configuration area, yet they're still present in the Views section along with their services. How do I get rid of them? I see there's a nagiosql_delete_host.php script, but i'm hesitant to use it without knowing what exactly it does.
Bryant
mguthrie
Re: Deleted Hosts & Services Still Showing in Views
Post by mguthrie »
Try these solutions and see if one of them resolves your issue.
http://support.nagios.com/wiki/index.ph ... lete_Hosts
bvinisky
Post by bvinisky »
Thank you kindly. Deleting the leftover cfg files from /usr/local/nagios/etc/hosts/ & /usr/local/nagios/etc/services/ did the trick.
Bryant
mguthrie
Post by mguthrie »
Good deal!
RCIJoe
Post by RCIJoe »
I have this issue. The host configuration files were not in either host or services directories. I tried all recommended solutions but the hosts continue to populate my service and host group views in XI.
RCIJoe,
We are going to have to look to see where these files are, can I have you run the following changing THE_HOST to the name of your host
grep -lir "THE_HOST" /usr/local/nagios/etc/*
RCIJoe
Post by RCIJoe »
scottwilkerson wrote:RCIJoe,
The only files returned were
/usr/local/nagios/etc/pnp/config.php
/usr/local/nagios/etc/pnp/npcd.cfg
/usr/local/nagios/etc/cgi.cfg
/usr/local/nagios/etc/commands.cfg
RCIJoe
Post by RCIJoe »
I think I misinterpreted "THE_HOST" and typed the nagios host name the first time. When I use the host name for the one I deleted I get no returns.
Lets run
service nagios stop
killall -9 nagios
service nagios start
Then look to see if the host still shows up in the web GUI
RCIJoe
Post by RCIJoe »
OK, had some other issues so I rebooted the XI server. Ghost hosts are gone. Thank you, JM
