Checks Stopped Functioning to A LOT OF DEVICES not all
rbuckle
Post by rbuckle »
My Nagios XI last night stopped processing checks for a large amount of my hosts.
Last Check: 2017-04-05 23:56:03
Next Check: 2017-04-06 09:10:08
It is currently 10:17 and this hasn't changed...
Any suggestions?
Running:
Installed Version: 5.8.3
OS: CentOS 7
Nagios XI
Enterprise License
Re: Checks Stopped Functioning to A LOT OF DEVICES not all
Post by dwhitfield »
Does date from the command line show the same thing as the Nagios XI time under Admin --> System Settings?
What about the output of grep date.timezone /etc/php.ini?
If those don't match, make those line up.
If they do match, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the Download Profile button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
