Hello,There
In my nagios core installation , recently i found that the retry-interval seems not working ,eg ,for server 'QX1' , i intended to set it as 1 min ,but actually in the log ,i see its 5 min between each check ,i check google and also this forum ,but haven't found why ,can you help to check,thanks .
real server 'QX1' ,use template 'pi-server'
template 'pi-server' ,use template 'generic-host'
check_interval 10
retry_interval 1
max_check_attempts 5
retry_interval 3
max_check_attempts 3
From the following log ,i see the retry-interval is 5 min , not the 1 min as wanted .
nagios-03-06-2017-00.log:[1488668959] HOST ALERT: QX1;DOWN;SOFT;1;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-06-2017-00.log:[1488669262] HOST ALERT: QX1;DOWN;SOFT;2;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-06-2017-00.log:[1488669562] HOST ALERT: QX1;DOWN;SOFT;3;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-06-2017-00.log:[1488669863] HOST ALERT: QX1;DOWN;SOFT;4;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-06-2017-00.log:[1488670162] HOST ALERT: QX1;DOWN;HARD;5;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-06-2017-00.log:[1488670464] HOST ALERT: QX1;UP;HARD;5;HTTP WARNING: HTTP/1.1 404 Not Found - 2122 bytes in 0.060 second response time
nagios-03-09-2017-00.log:[1488983853] HOST ALERT: QX1;DOWN;SOFT;1;HTTP CRITICAL: HTTP/1.0 503 Service Unavailable - 313 bytes in 0.065 second response time
nagios-03-09-2017-00.log:[1488984160] HOST ALERT: QX1;DOWN;SOFT;2;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-09-2017-00.log:[1488984521] HOST ALERT: QX1;UP;SOFT;3;HTTP WARNING: HTTP/1.1 404 Not Found - 2122 bytes in 0.046 second response time
nagios-03-13-2017-00.log:[1489273503] HOST ALERT: QX1;DOWN;SOFT;1;HTTP CRITICAL: HTTP/1.0 503 Service Unavailable - 313 bytes in 0.066 second response time
nagios-03-13-2017-00.log:[1489273806] HOST ALERT: QX1;DOWN;SOFT;2;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-13-2017-00.log:[1489274106] HOST ALERT: QX1;DOWN;SOFT;3;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-13-2017-00.log:[1489274406] HOST ALERT: QX1;DOWN;SOFT;4;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-13-2017-00.log:[1489274706] HOST ALERT: QX1;DOWN;HARD;5;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-13-2017-00.log:[1489275307] HOST ALERT: QX1;UP;HARD;5;HTTP WARNING: HTTP/1.1 404 Not Found - 2122 bytes in 0.024 second response time
nagios-03-20-2017-00.log:[1489878495] HOST ALERT: QX1;DOWN;SOFT;1;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-20-2017-00.log:[1489878803] HOST ALERT: QX1;DOWN;SOFT;2;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-20-2017-00.log:[1489879102] HOST ALERT: QX1;DOWN;SOFT;3;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-20-2017-00.log:[1489879402] HOST ALERT: QX1;DOWN;SOFT;4;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-20-2017-00.log:[1489879703] HOST ALERT: QX1;DOWN;HARD;5;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-20-2017-00.log:[1489880306] HOST ALERT: QX1;UP;HARD;5;HTTP WARNING: HTTP/1.1 404 Not Found - 2122 bytes in 0.024 second response time
nagios-03-22-2017-00.log:[1490123480] HOST ALERT: QX1;DOWN;SOFT;1;CRITICAL - Socket timeout
nagios-03-22-2017-00.log:[1490123852] HOST ALERT: QX1;UP;SOFT;2;HTTP WARNING: HTTP/1.1 404 Not Found - 2100 bytes in 0.012 second response time
nagios-03-27-2017-00.log:[1490483233] HOST ALERT: QX1;DOWN;SOFT;1;HTTP CRITICAL: HTTP/1.0 503 Service Unavailable - 313 bytes in 0.064 second response time
nagios-03-27-2017-00.log:[1490483543] HOST ALERT: QX1;DOWN;SOFT;2;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-27-2017-00.log:[1490483842] HOST ALERT: QX1;DOWN;SOFT;3;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-27-2017-00.log:[1490484141] HOST ALERT: QX1;DOWN;SOFT;4;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-27-2017-00.log:[1490484440] HOST ALERT: QX1;DOWN;HARD;5;connect to address qx1.qx1.com and port 58201: Connection refused
nagios-03-27-2017-00.log:[1490487441] HOST ALERT: QX1;UP;HARD;5;HTTP WARNING: HTTP/1.1 404 Not Found - 2122 bytes in 0.019 second response time
retry-interval seems not working in my configuration
Re: retry-interval seems not working in my configuration
Can you share the full host/template definitions for each of the referenced objects?
Hi,mcapra
Thanks for the reply
,as the full config file contains quite a lot server info , here are the host/host template defination relates to the server QX1
in piQ.cfg config file
in template.cfg config file
name pi-server ; The name of this host template
use generic-host ; Inherit default values from the generic-host template
check_interval 10
retry_interval 1
check_command check_pi_host_wo_nepp ; Default command to check if servers are "alive"
notification_interval 10080 ; Resend notifications every 30 minutes
notification_options d,r ; Only send notifications for specific host states
notification_period EAI_24x7 ;
contact_groups EAI_pi
contacts *******
register 0 ; DONT REGISTER THIS - ITS JUST A TEMPLATE
use pi-server
host_name QX1
alias QX1_URL_HERE
address QX1_URL_HERE
_pi_usr *******
_pi_pwd *********
_pi_port 58201
_p4_port 58204
_pi_sapctrl_port 58213
}in template.cfg config file
name generic-host ; The name of this host template
notifications_enabled 1 ; Host notifications are enabled
notification_interval 0 ; Do not resend notifications
notification_options d,u,r ; Only send notifications for specific host states
event_handler_enabled 1 ; Host event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
retry_interval 3 ; Schedule host check retries at 3 minute intervals
max_check_attempts 3 ; Check each host 3 times (max)
contact_groups admins ; Notifications get sent to the admins by default
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL HOST, JUST A TEMPLATE!
}Re: retry-interval seems not working in my configuration
Which version of Nagios Core are you using? With that exact setup using Nagios Core 4.3.1, I am getting a 1 minute retry interval:
[1492184422] HOST ALERT: QX1;DOWN;SOFT;2;check_dummy: Arguments to check_dummy must be an integer
[1492184481] HOST ALERT: QX1;DOWN;SOFT;3;check_dummy: Arguments to check_dummy must be an integer
[1492184539] HOST ALERT: QX1;DOWN;SOFT;4;check_dummy: Arguments to check_dummy must be an integer
[1492184599] HOST ALERT: QX1;DOWN;HARD;5;check_dummy: Arguments to check_dummy must be an integerFormer Nagios employee
i am using nagios core 4.2.1
Current Network Status
Last Updated: Mon Apr 17 03:28:10 CEST 2017
Updated every 30 seconds
Nagios® Core™ 4.2.1 - www.nagios.org
Hmm, still unable to replicate it on a 4.2.1 machine:
Can you share your full objects.cache file? It's typically located here:
[1492447938] HOST ALERT: QX1;DOWN;SOFT;1;check_dummy: Arguments to check_dummy must be an integer
[1492447998] HOST ALERT: QX1;DOWN;SOFT;2;check_dummy: Arguments to check_dummy must be an integer
[1492448058] HOST ALERT: QX1;DOWN;SOFT;3;check_dummy: Arguments to check_dummy must be an integer
[1492448118] HOST ALERT: QX1;DOWN;SOFT;4;check_dummy: Arguments to check_dummy must be an integer
[1492448178] HOST ALERT: QX1;DOWN;HARD;5;check_dummy: Arguments to check_dummy must be an integer
/usr/local/nagios/var/objects.cacheFormer Nagios employee
Hello,Mcapra
Sorry for the late response ,thanks but as the whole file contain quite a lot server info of our company ,i can't provide it by company's security policy. Here's the QX1 defination in this file .
Can you hint me some clue to find out the reason ,maybe then i can try first to check myself.
define host {
host_name QX1
alias qx1.server.xx.com
address qx1.server.xx.com
contacts gom999
initial_state o
importance 0
check_interval 10.000000
retry_interval 1.000000
active_checks_enabled 1
passive_checks_enabled 1
obsess 1
low_flap_threshold 0.000000
high_flap_threshold 0.000000
flap_detection_options a
freshness_threshold 0
check_freshness 0
notification_options r,d
notification_interval 10080.000000
first_notification_delay 0.000000
stalking_options n
process_perf_data 1
_PI_USR QX0_NAGIOS
_PI_PWD *******
_PI_PORT 58201
_P4_PORT 58204
_PI_SAPCTRL_PORT 58213
define host {
host_name QX1
contacts gom999
initial_state o
importance 0
obsess 1
check_freshness 0
stalking_options n
process_perf_data 1
_PI_USR QX0_NAGIOS
_PI_PWD *******
_PI_PORT 58201
_P4_PORT 58204
avandemore
Can you attach nagios.cfg? That may provide some clues.
Previous Nagios employee
