I was looking into creating users thru the API, http://myhost/nagiosxi/help/api-system- ... p#add-user, however, by default you have to specify a password. Is it possible to create a user who can log in with the AD credentials? The AD integration is ready and complete. I can create a user by hand and specify the AD that is used. I don't see that option thru the API though.
Create user with AD integration thru API
- tacolover101
Re: Create user with AD integration thru API
i don't think this is currently possible, but it makes for a great feature request.
This does not exist currently, but may in the future in our quest to have the API do "all the things".
You could almost certainly write a custom API endpoint to do that, though the work would be non-trivial. See the "Help" section of Nagios XI for more information about custom API endpoints.
I was able to reverse engineer the call that the browser makes. To summarize:
I'm hitting the login.php page with a HTTP GET first. From there I collect the nsp and nagiosxi cookie. I then submit a HTTP POST request with the following payload:
nsp=<previouslyCollectedNspString>&page=auth&debug=&pageopt=login&username=nagiosadmin&password=<ourAdminPassword>&loginButton=
Note that you'll have to set the cookie as an http header.
Successful authentication will give me a 302 HTTP code.
I'll then do an HTTP POST to /nagiosxi/admin/users.php?users&edit=1 with the following payload (cookie still needs to be provided):
update=1&nsp=<previouslyCollectedNspString>&users=1&user_id%5B%5D=&username=pew&password1=TQKiGL&password2=TQKiGL&forcepasswordchange=on&sendemail=on&name=pew&email=pew%40pew&add_contact=on&enable_notifications=on&enabled=on&language=en_US&defaultDateFormat=1&defaultNumberFormat=2&auth_type=ad&ad_server=58ee4f504571d&ad_username=asdf&dn=&level=1&updateButton=Add+User
this will create the user "pew" and connects it to the AD user "asdf" on our previously defined AD server "58ee4f504571d". I found the AD server by looking at the HTML code. Is there an easier way to get this value?
I do agree that this would be a great feature request. Instead of going thru the whole authentication flow and doing it this "hack", it would be nice to just specify it thru the API.
The value is stored in the nagiosxi.xi_options table where name='ldap_ad_integration_component_servers'. It's base64 encoded, so you decode that to get the serialized PHP which represents something like this:ps469x wrote: This will create the user "pew" and connects it to the AD user "asdf" on our previously defined AD server "58ee4f504571d". I found the AD server by looking at the HTML code. Is there an easier way to get this value?
[0] => Array
[id] => 58c08a28ea367
[enabled] => 1
[conn_method] => ad
[ad_account_suffix] => @DOMAIN.local
[ad_domain_controllers] => 192.168.67.99
[base_dn] => DC=DOMAIN,DC=local
[security_level] => none
[ldap_port] =>
[ldap_host] =>
)Former Nagios employee
