I can't quite figure this one out. Getting the below error:
check_swap: Warning percentage should be more than critical percentage
Plugin version is 2.1.4
command_line $USER1$/check_swap -w $ARG1$ -c $ARG2$
Anyone else come across this error? Any help is appreciated.
check_swap error
Re: check_swap error
The check_swap plugin is used to check how much free swap is on the system so the warning threshold has to be larger than the critical threshold for the plugin to function.
That is what the message is telling you.
If you run the command like the example below
It will generate a warning alert when the amount of free swap falls below 50% and generate a critical alert when the amount of free swap falls below 20%.
If you have any other questions about this, please post them.
check_swap -w 50% -c 20%If you have any other questions about this, please post them.
