Unable to execute a application specific cmd using check_nrp
Re: Unable to execute a application specific cmd using check
Edit the check_by_ssh_watchque command in the nagios config file and change the command_line from
command_line    $USER1$/check_by_ssh -z -E -S -t 20 -H $HOSTADDRESS$ -C "/usr/local/nagios/libexec/check_watchque"
to
command_line    $USER1$/check_by_ssh -z -E -t 20 -H $HOSTADDRESS$ -C "/usr/local/nagios/libexec/check_watchque"
Save the changes and restart nagios
Then edit the /usr/local/nagios/libexec/check_watchque on the remote system and change this line from
MsgRate=`/bin/cat /tmp/watchqueue_1.txt  | /bin/grep 'Total UDP Messages' | /bin/awk '{print $9}' | /bin/sed 's/(//g'`
to
MsgRate=`/bin/cat /tmp/watchqueue_1.txt  | /bin/grep 'Total UDP Messages' | /bin/awk '{print $9}' | /bin/sed 's/\x1b[\[(0-9a-zA-Z;]*//g'`
Save the file
If the plugin returns valid data and also valid performance data, You can check that by selecting the service from the GUI, then the graph should start to populate.
With all of the changes, you may have to delete the .xml and .rrd files so the graph will rebuild itself with valid data.
diwakar0304
Post by diwakar0304 »
Current code as per your advice:
#!/bin/bash
EPOC1=`/bin/date +%s`
sudo /<Path to cmd>/watchqueue 1
EPOC2=`/bin/cat /tmp/watchqueue_1.txt | /bin/grep shm | /usr/bin/head -1 | /bin/awk '{print $7}' | /bin/sed 's/(//g;s/)//g'1`
        if [ "$EPOC2" -ge "$EPOC1" ]
          then
               #MsgRate=`/bin/cat /tmp/watchqueue_1.txt  | /bin/grep 'Total UDP Messages' | /bin/awk '{print $9}' | /bin/sed 's/(//g'`
                   /bin/echo -e "Ok: Message rate is $MsgRate | $MsgRate"
                   exit 0
           else
               /bin/echo -e "Critical: File /tmp/watchqueue_1.txt is not generated with current time"
                   exit 2
        fi
output on CLI:
[nagios@NVMBRCPGNAT006VM3 ~]$  /usr/local/nagios/libexec/check_by_ssh -v -E -z -H <Remote server IP> -C "/usr/local/nagios/libexec/check_watchque"
Command: /usr/bin/ssh
Argument 1: -tt
Argument 2: <Remote server IP>
Argument 3: /usr/local/nagios/libexec/check_watchque
Ok: Message rate is (3 | (3
Nagios UI output:
Same error on performance part.
jfrickson
Post by jfrickson »
It looks like some of that output is from the line sudo /<Path to cmd>/watchqueue 1 at the top. Try changing that to sudo /<Path to cmd>/watchqueue 1 &>/dev/null and see how that works.
If that works, try changing the sed command back and try it again.
diwakar0304
&>/dev/null works!!!!!
Till this time sed command was like this
Then I have added suggested sed command
and getting below output:
Ok: Message rate is (1 | (1
To remove brackets, I added one more sed option next to your suggested one:
MsgRate=`/bin/cat /tmp/watchqueue_1.txt  | /bin/grep 'Total UDP Messages' | /bin/awk '{print $9}' | /bin/sed 's/\x1b[\[(0-9a-zA-Z;]*//g;s/(//g'`
But still not getting performance output. /usr/local/pnp4nagios/var/perfdata/<hostname> file for msg_rate itself is not getting generate. All other service are properly updating in this directory./
Strace_performance_not.txt
(6.47 KiB) Downloaded 371 times
BR///
I just want to verify but when the check is run, is this the output that is printed to the screen, or something simular?
Ok: Message rate is 0 | 0\r\n", 27Ok: Message rate is 0 | 0
If so, the output for the performance data is not formatted correctly and that is why the graphs are not getting created.
Take a look at this link to see how the performance data needs to be formatted.
https://nagios-plugins.org/doc/guidelines.html#AEN200
diwakar0304
Thanks every one for your efforts and support. Please lock this thread.
