notifications tab
notifications tab
When running a notifications report from the home tab the query takes an extended time to complete. Do you have any suggestions on how to speed this up ?
Re: notifications tab
What is an extended time in this situation? 1 minute, 2, 5? How many notifications total are listed when it eventually returns?
Are you applying any filters to limit the results to specific time period, host, groups, etc? Those are always options if you know kind of what you're looking for and should speed things up a bit.
when you launch the notifcations tab it just starts the default query I would say it takes about 5 minutes to finish if it doesn't crash the browser. When I look at top it looks like
mysqld hits 100% and stays - I have ran db repair without resolving the issue
When I close my browser mysqld goes back to 8 -10 %
I'll need to poke around a bit to see if there's something we can do to improve the performance of the default query, but in the meantime I believe I have a work around for you to try:
Open /usr/local/nagiosxi/html/reports/notifications.php and find the section that looks like:
This is the default query that is run. Edit one of the lines to restrict the default search. For example:
Save the changes to the file, restart the service with service nagios restat, test, and let us know if this helps.
PM me a system profile as well so that I can get a better idea of your Nagios setup. Profiles can be generated and downloaded under Admin > System Config > System Profile.
function display_notifications()
global $request;
// Makes sure user has appropriate license level
licensed_feature_check();
// Get values passed in GET/POST request
$page = grab_request_var("page", 0);
$reportperiod = grab_request_var("reportperiod", "last24hours");
$startdate = grab_request_var("startdate", "");
$enddate = grab_request_var("enddate", "");
$search = grab_request_var("search", "");
$host = grab_request_var("host", "");
$service = grab_request_var("service", "");
$hostgroup = grab_request_var("hostgroup", "");
$servicegroup = grab_request_var("servicegroup", "");
...Code: Select all
$search = grab_request_var("search", "localhost");PM me a system profile as well so that I can get a better idea of your Nagios setup. Profiles can be generated and downloaded under Admin > System Config > System Profile.
Received the profile but didn't see anything unusual. Please run the following to export a copy of the notifications table and PM the resulting notifications.sql file:
mysqldump -uroot -pnagiosxi nagios nagios_notifications > notifications.sql
please see attched pm too big
Thanks for that! I loaded the table and the amount of entries(~60,000) wasn't causing any problems on a very modest test system. Reviewing the profile again I see that there is frequently a very high load on the machine due to processing performance data. I would recommend following https://assets.nagios.com/downloads/nag ... giosXI.pdf to setup a RAM disk to help with performance. The guide goes into a lot of detail, but the installation is pretty quick and is summed up with:
cd /tmp
wget https://assets.nagios.com/downloads/nag ... ramdisk.sh
chmod +x install_ramdisk.sh
./install_ramdisk.sh
cd /tmp
Ok we will give it a shot thank you
No problem. Look forward to your update.
unfortunaley not better on the notifications link. What is odd is that i ran a "event log" query and the result 4.000 + records came back in like 5- 10 seconds
