Upgrade 5.4.3 to 5.4.4 fails with 403 Forbidden
CBoekhuis
Post by CBoekhuis »
i was upgrading a nagiosxi through the GUI from 5.4.3 to 5.4.4. While trying to get some packages the installer raised an error . See logging below.
Any idea?
Backup stored in /store/backups/nagiosxi/autoupgrade_backup.1493208325.tar.gz
---- Starting Nagios XI Upgrade ----
Cleaning up temp directory...
No entry for terminal type "unknown";
using dumb terminal settings.
Archive:  sourceguardian/ixed4.lin.x86-64.zip
  inflating: /usr/lib64/php/modules/ixed.5.3.lin
Sourceguardian extension found for PHP version 5.3
Sourceguardian extension already in php.ini
Stopping httpd: [  OK  ]
Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using nagiosxi.some.name for ServerName
[  OK  ]
Checking required prereqs...
Please wait...
OLD VERSION: 5403
Loaded plugins: fastestmirror, refresh-packagekit, security
Setting up Install Process
Loading mirror speeds from cached hostfile
* base: centos.mirror.triple-it.nl
* epel: epel.mirror.wearetriple.com
* extras: centos.mirror.triple-it.nl
* updates: mirrors.supportex.net
Package automake-1.11.1-4.el6.noarch already installed and latest version
Package autoconf-2.63-5.1.el6.noarch already installed and latest version
Package 2:nmap-6.47-1.x86_64 already installed and latest version
Package subversion-1.6.11-15.el6_7.x86_64 already installed and latest version
Resolving Dependencies
--> Running transaction check
---> Package php-mbstring.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php-mbstring.x86_64 0:5.3.3-49.el6 will be an update
--> Processing Dependency: php-common(x86-64) = 5.3.3-49.el6 for package: php-mbstring-5.3.3-49.el6.x86_64
---> Package php-common.x86_64 0:5.3.3-48.el6_8 will be updated
--> Processing Dependency: php-common(x86-64) = 5.3.3-48.el6_8 for package: php-xml-5.3.3-48.el6_8.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-48.el6_8 for package: php-5.3.3-48.el6_8.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-48.el6_8 for package: php-gd-5.3.3-48.el6_8.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-48.el6_8 for package: php-ldap-5.3.3-48.el6_8.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-48.el6_8 for package: php-cli-5.3.3-48.el6_8.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-48.el6_8 for package: php-pdo-5.3.3-48.el6_8.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-48.el6_8 for package: php-mysql-5.3.3-48.el6_8.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-48.el6_8 for package: php-snmp-5.3.3-48.el6_8.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-48.el6_8 for package: php-pgsql-5.3.3-48.el6_8.x86_64
---> Package php-common.x86_64 0:5.3.3-49.el6 will be an update
---> Package php.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-cli.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php-cli.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-gd.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php-gd.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-ldap.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php-ldap.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-mysql.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php-mysql.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-pdo.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php-pdo.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-pgsql.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php-pgsql.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-snmp.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php-snmp.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-xml.x86_64 0:5.3.3-48.el6_8 will be updated
---> Package php-xml.x86_64 0:5.3.3-49.el6 will be an update
Dependencies Resolved
Package              Arch           Version                 Repository    Size
Updating:
php-mbstring         x86_64         5.3.3-49.el6            base         460 k
Updating for dependencies:
php                  x86_64         5.3.3-49.el6            base         1.1 M
php-cli              x86_64         5.3.3-49.el6            base         2.2 M
php-common           x86_64         5.3.3-49.el6            base         530 k
php-gd               x86_64         5.3.3-49.el6            base         111 k
php-ldap             x86_64         5.3.3-49.el6            base          43 k
php-mysql            x86_64         5.3.3-49.el6            base          86 k
php-pdo              x86_64         5.3.3-49.el6            base          80 k
php-pgsql            x86_64         5.3.3-49.el6            base          75 k
php-snmp             x86_64         5.3.3-49.el6            base          36 k
php-xml              x86_64         5.3.3-49.el6            base         108 k
Transaction Summary
Upgrade      11 Package(s)
Total download size: 4.8 M
Downloading Packages:
Total                                           3.1 MB/s | 4.8 MB     00:01
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
  Updating   : php-common-5.3.3-49.el6.x86_64                              1/22
  Updating   : php-pdo-5.3.3-49.el6.x86_64                                 2/22
  Updating   : php-cli-5.3.3-49.el6.x86_64                                 3/22
  Updating   : php-5.3.3-49.el6.x86_64                                     4/22
  Updating   : php-mysql-5.3.3-49.el6.x86_64                               5/22
  Updating   : php-pgsql-5.3.3-49.el6.x86_64                               6/22
  Updating   : php-mbstring-5.3.3-49.el6.x86_64                            7/22
  Updating   : php-ldap-5.3.3-49.el6.x86_64                                8/22
  Updating   : php-xml-5.3.3-49.el6.x86_64                                 9/22
  Updating   : php-snmp-5.3.3-49.el6.x86_64                               10/22
  Updating   : php-gd-5.3.3-49.el6.x86_64                                 11/22
  Cleanup    : php-pgsql-5.3.3-48.el6_8.x86_64                            12/22
  Cleanup    : php-mysql-5.3.3-48.el6_8.x86_64                            13/22
  Cleanup    : php-5.3.3-48.el6_8.x86_64                                  14/22
  Cleanup    : php-cli-5.3.3-48.el6_8.x86_64                              15/22
  Cleanup    : php-pdo-5.3.3-48.el6_8.x86_64                              16/22
  Cleanup    : php-gd-5.3.3-48.el6_8.x86_64                               17/22
  Cleanup    : php-snmp-5.3.3-48.el6_8.x86_64                             18/22
  Cleanup    : php-xml-5.3.3-48.el6_8.x86_64                              19/22
  Cleanup    : php-ldap-5.3.3-48.el6_8.x86_64                             20/22
  Cleanup    : php-mbstring-5.3.3-48.el6_8.x86_64                         21/22
  Cleanup    : php-common-5.3.3-48.el6_8.x86_64                           22/22
  Verifying  : php-cli-5.3.3-49.el6.x86_64                                 1/22
  Verifying  : php-5.3.3-49.el6.x86_64                                     2/22
  Verifying  : php-common-5.3.3-49.el6.x86_64                              3/22
  Verifying  : php-mbstring-5.3.3-49.el6.x86_64                            4/22
  Verifying  : php-ldap-5.3.3-49.el6.x86_64                                5/22
  Verifying  : php-xml-5.3.3-49.el6.x86_64                                 6/22
  Verifying  : php-snmp-5.3.3-49.el6.x86_64                                7/22
  Verifying  : php-pdo-5.3.3-49.el6.x86_64                                 8/22
  Verifying  : php-mysql-5.3.3-49.el6.x86_64                               9/22
  Verifying  : php-pgsql-5.3.3-49.el6.x86_64                              10/22
  Verifying  : php-gd-5.3.3-49.el6.x86_64                                 11/22
  Verifying  : php-gd-5.3.3-48.el6_8.x86_64                               12/22
  Verifying  : php-snmp-5.3.3-48.el6_8.x86_64                             13/22
  Verifying  : php-cli-5.3.3-48.el6_8.x86_64                              14/22
  Verifying  : php-5.3.3-48.el6_8.x86_64                                  15/22
  Verifying  : php-pgsql-5.3.3-48.el6_8.x86_64                            16/22
  Verifying  : php-mbstring-5.3.3-48.el6_8.x86_64                         17/22
  Verifying  : php-mysql-5.3.3-48.el6_8.x86_64                            18/22
  Verifying  : php-ldap-5.3.3-48.el6_8.x86_64                             19/22
  Verifying  : php-pdo-5.3.3-48.el6_8.x86_64                              20/22
  Verifying  : php-xml-5.3.3-48.el6_8.x86_64                              21/22
  Verifying  : php-common-5.3.3-48.el6_8.x86_64                           22/22
Updated:
Dependency Updated:
  php.x86_64 0:5.3.3-49.el6               php-cli.x86_64 0:5.3.3-49.el6
  php-common.x86_64 0:5.3.3-49.el6        php-gd.x86_64 0:5.3.3-49.el6
  php-ldap.x86_64 0:5.3.3-49.el6          php-mysql.x86_64 0:5.3.3-49.el6
  php-pdo.x86_64 0:5.3.3-49.el6           php-pgsql.x86_64 0:5.3.3-49.el6
  php-snmp.x86_64 0:5.3.3-49.el6          php-xml.x86_64 0:5.3.3-49.el6
Complete!
* updates: ftp.tudelft.nl
Package perl-Class-Accessor-0.31-6.1.el6.noarch already installed and latest version
Package perl-Params-Validate-0.92-3.el6.x86_64 already installed and latest version
Package perl-Config-Tiny-2.12-7.1.el6.noarch already installed and latest version
Package perl-Math-Calc-Units-1.07-6.el6.noarch already installed and latest version
Package perl-Number-Format-1.73-3.el6.noarch already installed and latest version
---> Package perl-Test-Simple.x86_64 0:0.92-141.el6_7.1 will be updated
---> Package perl-Test-Simple.x86_64 0:0.92-144.el6 will be an update
--> Processing Dependency: perl = 4:5.10.1-144.el6 for package: perl-Test-Simple-0.92-144.el6.x86_64
---> Package perl.x86_64 4:5.10.1-141.el6_7.1 will be updated
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 1:perl-Digest-SHA-5.47-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 4:perl-devel-5.10.1-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 1:perl-Pod-Escapes-1.04-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: perl-Test-Harness-3.17-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: perl-IO-Compress-Base-2.021-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 1:perl-ExtUtils-ParseXS-2.2003.0-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 1:perl-Compress-Raw-Zlib-2.021-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: perl-CGI-3.51-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 3:perl-version-0.77-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: perl-ExtUtils-MakeMaker-6.55-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 4:perl-Time-HiRes-1.9721-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: perl-CPAN-1.9402-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: perl-IO-Compress-Zlib-2.021-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 1:perl-Module-Pluggable-3.90-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: perl-Compress-Zlib-2.021-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 4:perl-libs-5.10.1-141.el6_7.1.x86_64
--> Processing Dependency: perl = 4:5.10.1-141.el6_7.1 for package: 1:perl-Pod-Simple-3.13-141.el6_7.1.x86_64
---> Package perl.x86_64 4:5.10.1-144.el6 will be an update
---> Package perl-CGI.x86_64 0:3.51-141.el6_7.1 will be updated
---> Package perl-CGI.x86_64 0:3.51-144.el6 will be an update
---> Package perl-CPAN.x86_64 0:1.9402-141.el6_7.1 will be updated
---> Package perl-CPAN.x86_64 0:1.9402-144.el6 will be an update
---> Package perl-Compress-Raw-Zlib.x86_64 1:2.021-141.el6_7.1 will be updated
---> Package perl-Compress-Raw-Zlib.x86_64 1:2.021-144.el6 will be an update
---> Package perl-Compress-Zlib.x86_64 0:2.021-141.el6_7.1 will be updated
---> Package perl-Compress-Zlib.x86_64 0:2.021-144.el6 will be an update
---> Package perl-Digest-SHA.x86_64 1:5.47-141.el6_7.1 will be updated
---> Package perl-Digest-SHA.x86_64 1:5.47-144.el6 will be an update
---> Package perl-ExtUtils-MakeMaker.x86_64 0:6.55-141.el6_7.1 will be updated
---> Package perl-ExtUtils-MakeMaker.x86_64 0:6.55-144.el6 will be an update
---> Package perl-ExtUtils-ParseXS.x86_64 1:2.2003.0-141.el6_7.1 will be updated
---> Package perl-ExtUtils-ParseXS.x86_64 1:2.2003.0-144.el6 will be an update
---> Package perl-IO-Compress-Base.x86_64 0:2.021-141.el6_7.1 will be updated
---> Package perl-IO-Compress-Base.x86_64 0:2.021-144.el6 will be an update
---> Package perl-IO-Compress-Zlib.x86_64 0:2.021-141.el6_7.1 will be updated
---> Package perl-IO-Compress-Zlib.x86_64 0:2.021-144.el6 will be an update
---> Package perl-Module-Pluggable.x86_64 1:3.90-141.el6_7.1 will be updated
---> Package perl-Module-Pluggable.x86_64 1:3.90-144.el6 will be an update
---> Package perl-Pod-Escapes.x86_64 1:1.04-141.el6_7.1 will be updated
---> Package perl-Pod-Escapes.x86_64 1:1.04-144.el6 will be an update
---> Package perl-Pod-Simple.x86_64 1:3.13-141.el6_7.1 will be updated
---> Package perl-Pod-Simple.x86_64 1:3.13-144.el6 will be an update
---> Package perl-Test-Harness.x86_64 0:3.17-141.el6_7.1 will be updated
---> Package perl-Test-Harness.x86_64 0:3.17-144.el6 will be an update
---> Package perl-Time-HiRes.x86_64 4:1.9721-141.el6_7.1 will be updated
---> Package perl-Time-HiRes.x86_64 4:1.9721-144.el6 will be an update
---> Package perl-devel.x86_64 4:5.10.1-141.el6_7.1 will be updated
---> Package perl-devel.x86_64 4:5.10.1-144.el6 will be an update
---> Package perl-libs.x86_64 4:5.10.1-141.el6_7.1 will be updated
---> Package perl-libs.x86_64 4:5.10.1-144.el6 will be an update
---> Package perl-version.x86_64 3:0.77-141.el6_7.1 will be updated
---> Package perl-version.x86_64 3:0.77-144.el6 will be an update
        Size
Updating:
perl-Test-Simple            x86_64     0.92-144.el6             base     113 k
perl                        x86_64     4:5.10.1-144.el6         base      10 M
perl-CGI                    x86_64     3.51-144.el6             base     210 k
perl-CPAN                   x86_64     1.9402-144.el6           base     247 k
perl-Compress-Raw-Zlib      x86_64     1:2.021-144.el6          base      70 k
perl-Compress-Zlib          x86_64     2.021-144.el6            base      46 k
perl-Digest-SHA             x86_64     1:5.47-144.el6           base      65 k
perl-ExtUtils-MakeMaker     x86_64     6.55-144.el6             base     294 k
perl-ExtUtils-ParseXS       x86_64     1:2.2003.0-144.el6       base      46 k
perl-IO-Compress-Base       x86_64     2.021-144.el6            base      70 k
perl-IO-Compress-Zlib       x86_64     2.021-144.el6            base     136 k
perl-Module-Pluggable       x86_64     1:3.90-144.el6           base      41 k
perl-Pod-Escapes            x86_64     1:1.04-144.el6           base      33 k
perl-Pod-Simple             x86_64     1:3.13-144.el6           base     213 k
perl-Test-Harness           x86_64     3.17-144.el6             base     232 k
perl-Time-HiRes             x86_64     4:1.9721-144.el6         base      49 k
perl-devel                  x86_64     4:5.10.1-144.el6         base     424 k
perl-libs                   x86_64     4:5.10.1-144.el6         base     579 k
perl-version                x86_64     3:0.77-144.el6           base      52 k
Transaction Summary
Upgrade      19 Package(s)
Total download size: 13 M
http://centos.mirror.triple-it.nl/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
Trying other mirror.
To address this issue please refer to the below knowledge base article
https://access.redhat.com/solutions/69319
If above article doesn't help to resolve this issue please open a ticket with Red Hat Support.
http://mirror.previder.nl/centos/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirror.proserve.nl/centos/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirrors.noction.com/centos/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://centos.mirror.transip.nl/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirror.yourwebhoster.eu/centos/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirror.nforce.com/pub/linux/CentOS/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirror.colocenter.nl/pub/centos/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirror.sitbv.nl/centos/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://centos.ams.host-engine.com/6.9/os/x86_64/Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
Error Downloading Packages:
  1:perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64: failure: Packages/perl-ExtUtils-ParseXS-2.2003.0-144.el6.x86_64.rpm from base: [Errno 256] No more mirrors to try.
Regards,
Christian
Reason: code blocks FTW
avandemore
Re: Upgrade 5.4.3 to 5.4.4 fails with 403 Forbidden
Post by avandemore »
Can you run this command first?
yum clean all
Previous Nagios employee
Post by dwhitfield »
In addition to what @avandemore said, I'd add the following two commands (his command should be run first though)
rm -rf /var/cache/yum
setenforce 0
This time, rather than upgrade from the UI, try the command line and see if you get the same errors: https://assets.nagios.com/downloads/nag ... nstall.pdf
CBoekhuis
Post by CBoekhuis »
sorry for the late reaction, but it's Kings day today and we have a day off 8-)
I've tryied also the cli version. Same result.
I will run the upgrade also tomorrow on another server, just to compare. I'll get back to you.
Size
Updating:
Transaction Summary
http://mirror.prolocation.net/centos/6. ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirror.proserve.nl/centos/6.9/os ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://ftp.nluug.nl/ftp/pub/os/Linux/di ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://centos.mirror.transip.nl/6.9/os/ ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://nl.mirror.babylon.network/centos ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://centos.mirror.triple-it.nl/6.9/o ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirror.1000mbps.com/centos/6.9/o ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://linux.cs.uu.nl/centos/6.9/os/x86 ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirror.sitbv.nl/centos/6.9/os/x8 ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
http://mirror.serverbeheren.nl/centos/6 ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 403 Forbidden"
It's possible you just need to add different repos.
What's the output of yum repolist all?
Also, did you follow the instructions in your output at https://access.redhat.com/solutions/69319 ?
