A year or two back we tried to upgrade our Nagios XI installation to CentOS7. We tried doing this by building a new CentOS 7 server, backing up the original DB and restoring it to the new server with a fresh Nagios install. This caused several problems at the time and I was advised it would not work due to a change in DB software. The original server has been around a while and has been upgraded in place. If I remember correctly it is still using the older DB method which is the cause of the issue.
With all that said my question is this, is there a documented upgrade path to get around this issue or are we left with building a new server and re-configuring? We would like to migrate our service configurations and data to a new Nagios XI installation on a CentOS 7 server.
Thanks in advance for your time and help.
Upgrade path CentOS 6 to CentOS 7
Re: Upgrade path CentOS 6 to CentOS 7
The Backup and Restore scripts have been updated on the server so when a restore is run and it detects that the backup has the Postgres database, the restore script will restore the backup to the Postgres database on the new server.
Take a look at the Backing Up And Restoring Your Nagios XI System document at the link below and if you have any questions, let us know.
