PowerShell
supercom
PowerShell
Post by supercom »
hello ,
i want to use powershell from the nagios linux os .
how do i download and install powershell on the nagios linux os ?
anyone know the command for this ?
thanks .
Re: PowerShell
Post by dwhitfield »
What exactly are you trying to do? Strictly speaking, using PowerShell on Linux is not really a Nagios question.
If you scroll down a bit at https://www.howtogeek.com/267858/how-to ... x-or-os-x/ you'll see CentOS instructions for installing.
