Nagios Login Issue
Issac08
Nagios Login Issue
Post by Issac08 »
Hi All,
We have installed nagios on RHEL machine ,after the installation we cant able to login the nagios console .There was no errors while installation.
Regards
Re: Nagios Login Issue
Are you having trouble logging in to the Web interface or to the shell?
When you try and login, you get any errors?
Can you post a screen shot of the error so we can view it?
