Hello everyone,
I have configured our Nagios instance to monitor a Xerox printer with the Check_SNMP_Printer plugin (https://exchange.nagios.org/directory/P ... ck/details), and am receiving information fine. The issue is that it is the wrong information. It is returning the Transfer Belt info on all checks except the paper trays (screenshot1).
If I manually run the command, I get the same response (screenshot2). I have checked the script and the Universal SNMP OIDs are correct. for my printer. If I snmpwalk the OIDs listed, they return expected output.
I am a bit at a loss as to what the issue is. I can only assume something is wrong with the logic?
Any insight i can get on this is greatly appreciated!
Check_SNMP_Printer woes
- screenshot2.png (5.22 KiB) Viewed 2302 times
- Screenshot1.png (9.8 KiB) Viewed 2302 times
- Former Nagios Staff
Re: Check_SNMP_Printer woes
What version are you using? Once I know the version, I can test this. We didn't write this plugin, so we are unfamiliar with it. [email protected] is the developer.
I am using the most recent version, 4.0
avandemore
While we don't support 3rd party plugins, here is some information on creating your own since you already know how to make it work:
https://nagios-plugins.org/doc/guidelines.html
https://mathias-kettner.de/checkmk_localchecks.html
http://www.yourownlinux.com/2014/06/how ... cript.html
Previous Nagios employee
Just checking in since we have not heard from you in a while. Did @avandemore's post clear things up or has the issue otherwise been resolved?
