Hey guys i have a problem.
I installed my nagios on centos, all worked correctly.
I also added some generic hosts which also worked.
But when im adding windows-servers i get the Error: Could not find any hostgroup matching windows-servers.
I also get this error with the standard windows.cfg. i also created a hostgroup named windows-servers, same error
what can I do?
avandemore
Re: Error: Could not find any hostgroup matching windows-ser
Can you post the full command and output from where you see this message?
Previous Nagios employee
[xx@localhost ~]$ sudo /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
[sudo] password for xx:
Nagios Core 4.3.2
Last Modified: 2017-05-09
License: GPL
Reading configuration data...
Read main config file okay...
Error: Could not find any hostgroup matching 'windows-servers' (config file '/usr/local/nagios/etc/objects/neu/windows.cfg', starting on line 24)
Error: Failed to process hostgroup names for host 'pcstav' (config file '/usr/local/nagios/etc/objects/neu/windows.cfg', starting at line 24)
Nagios Core 4.3.2
License: GPL
avandemore
XI > Configure > Core Config Manager > Config File Management > Delete Files > Write Configs > Verify Files > Restart Nagios Core
Older Nagios Versions:
XI > Configure > Core Config Manager > Write Config Files > Delete > Write > Verify > Restart
Does that resolve your issue?
you have not added a hostgroup matching whatever is on that line:
cretae a hostgroup with the same name.
avandemore
Can you provide your /usr/local/nagios/etc/nagios.cfg along with any other cfg files it references?
To add the missing hostgroup to your system, edit this file
And add the hostgroup to it like the example below.
Save the file and restart the nagios process by running
As long as there are no other configuration errors, the nagios process should start up.
/usr/local/nagios/etc/objects/neu/windows.cfgCode: Select all
# Define a hostgroup for Windows machines
# All hosts that use the windows-server template will automatically be a member of this group
define hostgroup{
hostgroup_name windows-servers ; The name of the hostgroup
alias Windows Servers ; Long name of the group
}Code: Select all
service nagios restartBe sure to check out our Knowledgebase for helpful articles and solutions!
