Fresh install
Fresh install
I am unable to install Nagios XI on a RHEL 7 server
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or RedHat. Do NOT use this on a system that has been tasked with other purposes or has an existing
install of Nagios Core. To create such a clean install you should have selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n] Y
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-repos'...
Configuring Repos...
Passed New Subscription Check
package centos-release is not installed
An error has occurred:
ERROR: can not find RHNS CA file: /usr/share/rhn/RHN-ORG-TRUSTED-SSL-CERT
See /var/log/up2date for more information
ERROR: Please add the 'Optional' channel to your Red Hat systems subscriptions.
You can do so in the Redhat Network web interface or using the rhn-channel command.
or, install the yum-utils package and use the following command:
yum-config-manager --enable rhel-7-server-optional-rpms
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-repos'
RESULT=1
INSTALLATION ERROR!
Re: Fresh install
This appears to be a known issue with RHEL, did you check with your vendor?
https://access.redhat.com/solutions/26435
Apparently one of the causes is incorrect system date.
Previous Nagios employee
Re: Fresh install
Now I am seem to be getting this error
I should probably mention that this is a VM on AWS. this is an EC2 instance. this is a fresh install
[root@usvanagiosdev8 nagiosxi]# ./fullinstall
Unable to locate SystemId file. Is this system registered?
RESULT=1
INSTALLATION ERROR!
RESULT=1
INSTALLATION ERROR!
Re: Fresh install
Have you tried adding the Optional channel? It is required.
This issue is described in the following KB article:
https://support.nagios.com/kb/article/e ... tions.html
Re: Fresh install
Does the AWS host have internet access? Mine do not. Just wondering...
Steve B
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Re: Fresh install
What is the output from:
# yum repolist -v
Re: Fresh install
attached
Re: Fresh install
Yes, it does have access to the internet
Re: Fresh install
Doesn't look enabled. What was the full output from when you ran:
Have you reached out to your OS vendor on how to enable their own repositories?
You can print the available list like this: or check here:
https://access.redhat.com/documentation ... repos.html
# yum-config-manager --enable rhel-7-server-optional-rpms
# subscription-manager repos --list
