Force Check not working for host
We have a host where "Force an immediate check" is not working. The host is up and pingable and no errors are thrown for the force check. Service checks are working fine, however, when attempting to force an immediate check on the host the "Last Check:" date/timestamp does not get updated and new values are not displayed for rta, lost, etc. Issue is only with this particular host. Any ideas on what else I can check?
avandemore
Re: Force Check not working for host
Please provide the host name in question and the file /usr/local/nagios/var/status.dat
Previous Nagios employee
Sent you a PM.
avandemore
That seems to be pretty normal. Can you attempt a Force Check again, then generate a fresh profile and PM that to me as well?
XI > Admin > System Profile > Download Profile
Please include the zip file in your response.
avandemore
You should consider upgrading Nagios XI. You are missing important security and functionality updates.
Does it work if you use the Nagios Core interface? http://yourip/nagios/
What is the full output from the following?
# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfgPrevious Nagios employee
PM'd command output. The check does not work from core interface either.
avandemore
Message is sitting in my outbox. ?!?
- Former Nagios Staff
You could just past the output in a code block and scrub sensitive info. Please put the output in a code block. The "Code" button is the fifth from the left on the post input screen (between Quote and List).
Are you able to upgrade? Here are instructions, unless you are using the offline: https://assets.nagios.com/downloads/nag ... nstall.pdf
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 2041 services.
Checked 116 hosts.
Checked 12 host groups.
Checked 5 service groups.
Checked 26 contacts.
Checked 2 contact groups.
Checked 138 commands.
Checked 23 time periods.
Checked 0 host escalations.
Checked 116 hosts
Checked 0 host dependencies
Checked 23 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
