check_ESX UNKNOWN - plugin timed out (timeout 30s)
MouadMimouni
Post by MouadMimouni »
I have installed Nagios and I want to monitor esx servers, using the Plugin Check VMwre API, so I installed vSphere SDK for Perl, but when i log in on nagios I have the problem with the following message (ScreenShot)
Thank you for your reply
Re: check_ESX UNKNOWN - plugin timed out (timeout 30s)
Can you show us the actual command run from the command line, along with the output of it, and provide us with the URL download link to the plugin that you are currently using?
MouadMimouni
Here is the site where I downloaded the plugin : "https://github.com/op5/check_vmware_api", as well as the result of the command (screenshot).
There seems to be a bug with certain versions of the VMWare Perl SDK so try and install a newer version of the SDK and see if that fixes the issue.
https://communities.vmware.com/thread/488747
