MariadDB Query for Total alert generated from last WEEK/MONT
prasadt
Post by prasadt »
Hello Team,
As we are getting total alert information from the Nagios Core Dashboard, Can we get that total number of alerts from the Mariadb query.
We want that data in our application portal to show how many alerts generated every WEEK/MONTH/DAY.
For doing this we need mariadb Query to generate weekly monthly total alert like it is showing in the attachment.
Can you please check and let me know the Query.
Regards,
Manoj Namdev
How to generate alert from nagios core dashboard
Total Alert generated monthly
Re: MariadDB Query for Total alert generated from last WEEK/
Post by mcapra »
I'm a bit confused. Nagios Core doesn't have a MariaDB back-end. Unless you're referring to NagiosQL? Or Nagios XI?
If you wanted to do this programatically, I think the JSON Query Generator is probably the best route.
@mcapra is correct, this data isn't in a DB in Core by default
prasadt
Post by prasadt »
Thanks team,
Its great help you guys are genius.
Can you just tell me how i can run JSON Query means fields to get desired output.
I want to count weekly hard alerts from the nagios core server.. I am little bit confused in date format and some other fields.
Please help me.
Thanks for your prompt support also
prasadt
Post by prasadt »
Specifically confused with Date Format and how i can keep "start time" and "end time"
Post by mcapra »
prasadt wrote: I want to count
prasadt wrote:weekly
Your "Start Time" and "End Time" will need to be evaluated as unix epochs at the time you make the JSON Query request.
prasadt wrote:hard alerts
Which creates this request:
http://10.35.6.50/nagios/cgi-bin/archivejson.cgi?query=alertcount&statetypes=hard&starttime=1493657796&endtime=1497459396
Which returns this JSON structure:
    "format_version": 0,
    "result": {
        "query_time": 1497459542000,
        "cgi": "archivejson.cgi",
        "user": "nagiosadmin",
        "query": "alertcount",
        "query_status": "released",
        "program_start": 1497368308000,
        "last_data_update": 1497459181000,
        "type_code": 0,
        "type_text": "Success",
        "message": ""
    "data": {
        "selectors": {
            "starttime": 1493657796000,
            "endtime": 1497459396000,
            "statetypes": 1
        "count": 155
prasadt
Post by prasadt »
Thanks Mcapra,
Perfect Thanks a lot you saved my life.
I Got what i was looking and i tried from every wrong place but in only 1 days you guys have cracked this even i can say in just some minutes.
Thanks a lot for simplify this and given me in such a perfect query.
Have a nice DAY :-)
You can please close this ticket.
Regards,
Manoj Namdev
