Birdseye view, love it but hate it too
SteveBeauchemin
Post by SteveBeauchemin »
To get the most performance possible in the Nagios GUI I have made some small edits to timings and intervals.
One such change is to the Quick-View -> Birdseye - which was causing me grief without being obvious.
I needed to change timings in there that were coded into the javascript. I made changes as shown.
cd /usr/local/nagiosxi/html/includes/components/birdseye/includes
vi main.js
Change the following lines:
from
    // Display simple JS clock
    setInterval('update_clock()', 1000);
    // Display updates
    setInterval('update_display_view(show_handled)', 10000);
    setInterval('update_display_view(show_soft)', 10000);
    setInterval('update_display_list(show_handled)', 10000);
    setInterval('update_display_list(show_soft)', 10000);
to
    // changed to refresh one time per minute
    setInterval('update_clock()', 60000);
    // Display updates once a minute
    setInterval('update_display_view(show_handled)', 60000);
    setInterval('update_display_view(show_soft)', 60000);
    setInterval('update_display_list(show_handled)', 60000);
    setInterval('update_display_list(show_soft)', 60000);
Since the clock only updates once a minute now, there is no need to show the seconds
At bottom of the same file change
var str = hours + ":" + minutes + ":" + seconds + " " + post;
to
var str = hours + ":" + minutes + " " + post;
Next you have to tell the browser that the javascript in cache needs to be updated. To force this you have to increment the version number in the php code.
vi birdseye.php
Find and change from:
 <script type="text/javascript" src="includes/main.js"></script>
to:
<script type="text/javascript" src="includes/main.js?v=1.1"></script>
If there are ever changes to the javascript from this point forward, then the v=1.1 needs to change and the browser will update the cached javascript file.
This reduces load on the httpd processes and requires less overhead as the end user web browser requests refreshes less often. Birdseye had been grabbing a TON of data every 10 seconds. With a large site, you can tell that something is using resources.
Without these changes, if someone leaves the Birdseye view running overnight, my ipcs queue will eventually climb to more than a million backlogged items. Then the full queue will make the DB start to lose data. I finally got the javascript refresh piece figured out. I had made the change, but the workstations cache the js files and never refresh them.
But not any more.
If anyone is running a large installation, this simple refresh timing thing could be causing performance issues. I find that GUI refreshes less than one minute make no difference to the tool users. I have increased all the settings I can find such that GUI refreshes do not impact my server. One at a time, find and change. I have not heard that anyone even noticed. But the tool is definitely running better.
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Re: Birdseye view, love it but hate it too
Post by dwhitfield »
Thanks as always, Steve! Did you having anything else to add, or should we lock it up?
SteveBeauchemin
Sure - Lock is okay. I hope the changes I detailed help others. It is the little things that matter sometimes. When there are many little things, they sometimes add up to a big thing.
Steve B
