No, you need to restart the NSClient++ service on the client (Windows machine).After I make these changes do I need to restart nagios on the sever ?
NSClient++
Re: NSClient++
Re: NSClient++
I did what you asked me to do. I have restarted the NSClient++ (64) service. Do I need to do anything on the server?
Re: NSClient++
when running the command you wanted me to run I am getting an error
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Users\administrator.SG1>cd c:\
c:\>cd "Program Files"
c:\Program Files>cd "NSClient++"
c:\Program Files\NSClient++>nscp settings --generate --add-defaults --load-all
e rvice\NSClient++.cpp:347 Failed to register plugin: Could not load library: 1
114: A dynamic link library (DLL) initialization routine failed.
: c:\Program Files\NSClient++\\modules\DotnetPlugins.dll in file: DotnetPlugins
26: The specified module could not be found.
: c:\Program Files\NSClient++\\modules\PythonScript.dll in file: PythonScript
Adding default values
Unable to parse command line (settings): Key not found: /settings/NRPE/client/ha
ndlers
any idea how to fix this?
ndlers
Re: NSClient++
I have tried this on 4 different servers and I am still receiving the following error message:
Connect to address 192.168.1.6 and port 12489: Connection refused
I am not sure if that error I posted above has anything to do with it or if it just takes sometime. Please advise.
Re: NSClient++
From the Nag server I still see closed
Starting Nmap 6.40 ( http://nmap.org ) at 2017-06-20 11:01 PDT
Nmap scan report for goauld.sg1.allamericanasphalt.com (192.168.1.6)
Host is up (0.089s latency).
PORT STATE SERVICE
12489/tcp closed unknown
MAC Address: 1C:98:EC:11:37:D4 (Unknown)
PORT STATE SERVICE
Re: NSClient++
When I checked the nsclient.log file here is what I am seeing
2017-06-20 10:55:45: e:..\..\..\trunk\service\NSClient++.cpp:347: Failed to register plugin: Could not load library: 1114: A dynamic link library (DLL) initialization routine failed.: C:\Program Files\NSClient++\\modules\DotnetPlugins.dll in file: DotnetPlugins
2017-06-20 10:55:51: e:..\..\..\trunk\service\NSClient++.cpp:347: Failed to register plugin: Could not load library: 126: The specified module could not be found.: C:\Program Files\NSClient++\\modules\PythonScript.dll in file: PythonScript
I believe this may be causing the problem, but not really sure. Thanks
Re: NSClient++
I don't think this is what's causing the issue. Please, post the ENTIRE nsclient.ini file in code wraps.
- Former Nagios Staff
Re: NSClient++
What is 192.168.39.27? That's the server that is in your Windows logs, but not your XI server. It's also not one of the IPs you ran nmap against.
Going forward, please put your output in a code blocks, or attach files. The "Code" button is the fifth from the left on the post input screen (between Quote and List).
What version of NSClient are you using? We only support .4.4. Also, for clarity, we did not write NSClient. You may want to use NCPA if you continue to have issues with NSClient.
Re: NSClient++
Here is my nsclient config my nag server ip is 192.168.1.186
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/modules]
; CheckDisk - CheckDisk can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckDisk = 0
; Event log Checker. - Check for errors and warnings in the event log. This is only supported through NRPE so if you plan to use only NSClient this wont help you at all.
CheckEventLog = 0
; Check External Scripts - A simple wrapper to run external scripts and batch files.
CheckExternalScripts = 0
; Helper function - Various helper function to extend other checks. This is also only supported through NRPE.
CheckHelpers = 0
CheckLogFile = 0
; Check NSCP - Checkes the state of the agent
CheckNSCP = 0
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 0
; CheckTaskSched - CheckTaskSched can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckTaskSched = 0
; CheckTaskSched2 - CheckTaskSched2 can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckTaskSched2 = 0
; CheckWMI - CheckWMI can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckWMI = 1
; GraphiteClient - Graphite client
GraphiteClient = 0
; LUAScript - LUAScript...
LUAScript = 0
; NRDPClient - Passive check support over NRDP
NRDPClient = 0
; NRPE client - NRPE client
NRPEClient = 0
; NRPE server - A simple server that listens for incoming NRPE connection and handles them.
NRPEServer = 0
; NSCAClient - Passive check support over NSCA.
NSCAClient = 0
; NSCA server (no encryption) - A simple server that listens for incoming NSCA connection and handles them.
NSCAServer = 0
; NSClient server - A simple server that listens for incoming NSClient (check_nt) connection and handles them. Although NRPE is the preferred method NSClient is fully supported and can be used for simplicity or for compatibility.
NSClientServer = 0
; SMTPClient - Passive check support via SMTP
SMTPClient = 0
; Scheduler - A scheduler which schedules checks at regular intervals
Scheduler = 0
; SimpleCache module - Caches results for later checking.
SimpleCache = 0
; SimpleFileWriter module - FileWriters results for later checking.
SimpleFileWriter = 0
; SyslogClient - Passive check support via Syslog
SyslogClient = 0
[/settings/default]
; ALLOWED CIPHERS - A better value is: ALL:!ADH:!LOW:!EXP:!MD5:@STRENGTH
allowed ciphers = ADH
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = 192.168.1.186
; BIND TO ADDRESS - Allows you to bind server to a specific local address. This has to be a dotted ip address not a host name. Leaving this blank will bind to all available IP addresses.
bind to =
; CACHE ALLOWED HOSTS - If hostnames should be cached, improves speed and security somewhat but wont allow you to have dynamic IPs for your nagios server.
cache allowed hosts = true
; SSL CERTIFICATE -
certificate =
; INBOX - The default channel to post incoming messages on
inbox = inbox
; PASSWORD - Password used to authenticate againast server
password =
; TIMEOUT - Timeout when reading packets on incoming sockets. If the data has not arrived within this time we will bail out.
timeout = 30
; ENABLE SSL ENCRYPTION - This option controls if SSL should be enabled.
use ssl = true
; VERIFY MODE -
verify mode = none
[/settings/NSClient/server]
; PERFORMANCE DATA - Send performance data back to nagios (set this to 0 to remove all performance data).
performance data = true
; PORT NUMBER - Port to use for check_nt.
port = 12489
; Section for SMTP passive check module.
[/settings/NRDP/client]
; CHANNEL - The channel to listen to.
channel = NRDP
; HOSTNAME - The host name of this host if set to blank (default) the windows name of the computer will be used.
hostname = auto
; Target definition for: default
[/settings/NRDP/client/targets/default]
; TARGET ADDRESS - Target host address
address =
; RECIPIENT - Recipient of email message
recipient = nscp@localhost
; SENDER - Sender of email message
sender = nscp@localhost
; TEMPLATE - Template for message data
template = Hello, this is %source% reporting %message%!
; TIMEOUT - Timeout when reading/writing packets to/from sockets.
timeout = 30
; Section for NRPE active/passive check module.
[/settings/NRPE/client]
channel = NRPE
[/settings/NRPE/client/targets/default]
address =
; SSL CERTIFICATE -
certificate =
; PAYLOAD LENGTH - Length of payload to/from the NRPE agent. This is a hard specific value so you have to "configure" (read recompile) your NRPE agent to use the same value for it to work.
payload length = 1024
timeout = 30
use ssl = true
; VERIFY MODE -
verify mode = none
; Section for NRPE (NRPEServer.dll) (check_nrpe) protocol options.
[/settings/NRPE/server]
; COMMAND ARGUMENT PROCESSING - This option determines whether or not the we will allow clients to specify arguments to commands that are executed.
allow arguments = false
; COMMAND ALLOW NASTY META CHARS - This option determines whether or not the we will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow nasty characters = false
; PORT NUMBER - Port to use for NRPE.
port = 5666
; Section for NSCA passive check module.
[/settings/NSCA/client]
channel = NSCA
hostname = auto
[/settings/NSCA/client/targets/default]
address =
; SSL CERTIFICATE -
certificate =
; ENCRYPTION METHOD - Number corresponding to the various encryption algorithms (see the wiki). Has to be the same as the server or it wont work at all.
encryption = aes
; PASSWORD - The password to use. Again has to be the same as the server or it wont work at all.
password =
timeout = 30
use ssl = false
; VERIFY MODE -
verify mode = none
; Section for NSCA (NSCAServer) (check_nsca) protocol options.
[/settings/NSCA/server]
; ENCRYPTION - Encryption to use
encryption = aes
; PASSWORD - Password to use
password =
; PAYLOAD LENGTH - Length of payload to/from the NSCA agent. This is a hard specific value so you have to "configure" (read recompile) your NSCA agent to use the same value for it to work.
payload length = 512
; PORT NUMBER - Port to use for NSCA.
port = 5667
use ssl = false
[/settings/SMTP/client]
channel = SMTP
[/settings/SMTP/client/targets/default]
address =
timeout = 30
; Section for simple cache module (SimpleCache.dll).
[/settings/cache]
channel = CACHE
; PRIMARY CACHE INDEX - Set this to the value you want to use as unique key for the cache (host, command, result,...).
primary index = ${alias-or-command}
; Section for system checks and system settings
[/settings/check/task schedule]
; SYNTAX - Set this to use a specific syntax string for all commands (that don't specify one)
default buffer length = %title% last run: %most-recent-run-time% (%exit-code%)
; Configure crash handling properties.
[/settings/crash]
; ARCHIVE CRASHREPORTS - Archive crash reports in the archive folder
archive = true
; folder - The archive folder for crash dunpes.
archive folder = ${shared-path}/crash-dumps
; RESTART - Submit crash reports to nsclient.org (or your configured submission server)
restart = true
; RESTART SERVICE NAME - The url to submit crash reports to
restart target = NSClientpp
; SUBMIT CRASHREPORTS - Submit crash reports to nsclient.org (or your configured submission server)
submit = false
; SUBMISSION URL - The url to submit crash reports to
submit url = http://crash.nsclient.org/submit
; Section for the EventLog Checker (CheckEventLog.dll).
[/settings/eventlog]
; BUFFER_SIZE - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
buffer size = 131072
; DEBUG - Log more information when filtering (usefull to detect issues with filters) not usefull in production as it is a bit of a resource hog.
debug = false
; LOOKUP NAMES - Lookup the names of eventlog files
lookup names = true
; SYNTAX - Set this to use a specific syntax string for all commands (that don't specify one).
syntax =
; A set of options to configure the real time checks
[/settings/eventlog/real-time]
; DEBUG - Log missed records (usefull to detect issues with filters) not usefull in production as it is a bit of a resource hog.
debug = false
; REAL TIME CHECKING - Spawns a backgrounnd thread which detects issues and reports them back instantly.
enabled = false
; LOGS TO CHECK - Comma separated list of logs to check
log = application,system
; STARTUP AGE - The initial age to scan when starting NSClient++
startup age = 30m
; A set of filters to use in real-time mode
[/settings/eventlog/real-time/filters]
; Section for external scripts configuration options (CheckExternalScripts).
[/settings/external scripts]
; SCRIPT DIRECTORY - Load all scripts in a directory and use them as commands. Probably dangerous but useful if you have loads of scripts
script path =
; COMMAND TIMEOUT - The maximum time in seconds that a command can execute. (if more then this execution will be aborted). NOTICE this only affects external commands not internal ones.
timeout = 60
; A list of aliases available. An alias is an internal command that has been "wrapped" (to add arguments). Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = checkCPU warn=80 crit=90 time=5m time=1m time=30s
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = checkProcState "$ARG1$=started"
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = checkProcState "$ARG1$=stopped"
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = checkServiceState CheckAll
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = checkUpTime MinWarn=1d MinWarn=1h
; alias_updates - Alias for alias_updates. To configure this item add a section called: /settings/external scripts/alias/alias_updates
alias_updates = check_updates -warning 0 -critical 0
; alias_volumes - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
alias_volumes = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
; alias_volumes_loose - Alias for alias_volumes_loose. To configure this item add a section called: /settings/external scripts/alias/alias_volumes_loose
alias_volumes_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED ignore-unreadable
; default - Alias for default. To configure this item add a section called: /settings/external scripts/alias/default
default =
; A list of scripts available to run from the CheckExternalScripts module. Syntax is: <command>=<script> <arguments>
; A list of wrappped scripts (ie. using the template mechanism)
; A list of templates for wrapped scripts
[/settings/external scripts/wrappings]
; BATCH FILE WRAPPING -
bat = scripts\\%SCRIPT% %ARGS%
; POWERSHELL WRAPPING -
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
; VISUAL BASIC WRAPPING -
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
; Section for graphite passive check module.
[/settings/graphite/client]
channel = GRAPHITE
hostname = auto
[/settings/graphite/client/targets/default]
address =
; PATH FOR VALUES -
path = system.${hostname}.${check_alias}.${perf_alias}
; Section for configuring the log handling.
[/settings/log]
; DATEMASK - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
date format = %Y-%m-%d %H:%M:%S
; FILENAME - The file to write log data to. Set this to none to disable log to file.
file name = ${exe-path}/nsclient.log
; Configure log file properties.
[/settings/log/file]
; MAXIMUM FILE SIZE - When file size reaches this it will be truncated to 50% if set to 0 (default) truncation will be disabled
max size = 0
; Section for log file checker
[/settings/logfile]
; DEBUG - Log more information to help diagnose errors and configuration problems.
debug = false
; SYNTAX - Set the default syntax to use
syntax =
[/settings/logfile/real-time]
; REAL TIME CHECKING - Spawns a backgrounnd thread which waits for file changes.
enabled = false
[/settings/logfile/real-time/checks]
; Section for the LUAScripts module.
[/settings/lua]
; A list of scripts available to run from the LuaSCript module.
[/settings/lua/scripts]
; Section for the Scheduler module.
[/settings/scheduler]
; THREAD COUNT - Number of threads to use.
threads = 5
[/settings/scheduler/schedules]
; Section for configuring the shared session.
[/settings/shared session]
; LOG LEVEL - Log level to use
enabled = false
; Section for SYSLOG passive check module.
[/settings/syslog/client]
channel = syslog
hostname =
[/settings/syslog/client/targets/default]
address =
; TODO -
critical severity = critical
; TODO -
facility = kernel
; TODO -
message_syntax = %message%
; TODO -
ok severity = informational
; TODO -
severity = error
; TODO -
tag_syntax = NSCA
; TODO -
unknown severity = emergency
; TODO -
warning severity = warning
[/settings/system/windows]
; DEFAULT LENGTH - Used to define the default intervall for range buffer checks (ie. CPU).
default buffer length = 1h
; Confiure which services has to be in which state
[/settings/system/windows/service mapping]
; A list of avalible remote target systems
[/settings/targets]
; Section for simple file writer module (SimpleFileWriter.dll).
[/settings/writers/file]
channel = FILE
; FILE TO WRITE TO - The filename to write output to.
file = output.txt
syntax = ${alias-or-command} ${result} ${message}
[/modules]
CheckDisk = 0
CheckEventLog = 0
CheckHelpers = 0
CheckLogFile = 0
CheckNSCP = 0
CheckSystem = 0
CheckTaskSched = 0
CheckTaskSched2 = 0
CheckWMI = 1
GraphiteClient = 0
LUAScript = 0
NRDPClient = 0
NRPEClient = 0
NRPEServer = 0
NSCAClient = 0
NSCAServer = 0
NSClientServer = 0
SMTPClient = 0
Scheduler = 0
SimpleCache = 0
SyslogClient = 0
[/settings/default]
bind to =
; SSL CERTIFICATE -
certificate =
inbox = inbox
password =
timeout = 30
use ssl = true
; VERIFY MODE -
verify mode = none
port = 12489
channel = NRDP
hostname = auto
address =
timeout = 30
channel = NRPE
address =
; SSL CERTIFICATE -
certificate =
timeout = 30
use ssl = true
; VERIFY MODE -
verify mode = none
port = 5666
channel = NSCA
hostname = auto
address =
; SSL CERTIFICATE -
certificate =
encryption = aes
password =
timeout = 30
use ssl = false
; VERIFY MODE -
verify mode = none
encryption = aes
password =
port = 5667
use ssl = false
channel = SMTP
address =
timeout = 30
[/settings/cache]
channel = CACHE
[/settings/crash]
archive = true
restart = true
submit = false
debug = false
lookup names = true
syntax =
debug = false
enabled = false
startup age = 30m
script path =
timeout = 60
default =
channel = GRAPHITE
hostname = auto
address =
; PATH FOR VALUES -
[/settings/log]
max size = 0
[/settings/logfile]
debug = false
syntax =
enabled = false
[/settings/lua]
threads = 5
enabled = false
channel = syslog
hostname =
address =
; TODO -
; TODO -
facility = kernel
; TODO -
; TODO -
; TODO -
severity = error
; TODO -
tag_syntax = NSCA
; TODO -
; TODO -
[/settings/targets]
channel = FILE
file = output.txt
