Nagios notification
ismail
Nagios notification
Post by ismail »
Hello
I have a big problem in Nagios email notification , I recive notification every 1 minute fore down services or host
I need to : recive notification : one alert when host or service is down
second alert when host or service is up
*******Ineed just 2 notification**********
Re: Nagios notification
Post by mcapra »
From this page:
notification_interval:
This directive is used to define the number of "time units" to wait before re-notifying a contact that this host is still down or unreachable. Unless you've changed the interval_length directive from the default value of 60, this number will mean minutes. If you set this value to 0, Nagios will not re-notify contacts about problems for this host - only one problem notification will be sent out.
Thanks @mcapra for the help.
Yes, setting the interval_length to 0 will only send one notification when a service or host changes state and not repeat the notifications.
