When I first installed my Nagios XI server, I experimented a little and ended up deleting all the "xiwizard_*" host and service templates. I didn't use the Configuration Wizards because I was making custom host and service templates at the time, so I never thought of doing a clean install again to restore them.
But now the server is in production and co-workers quite often poke at me to fix their Configuration Wizards generated hosts, because the missing "xiwizard_*" templates causes them to give errors. XI seem to automatically recreate a template when required, but it is left empty and disabled.
So is there a way I can get the configuration for all the "xiwizard_*" templates?
Maybe you can just give me a zip file with the configuration files? Then I can import them again.
Retoring xiwizard_* Templates
Re: Retoring xiwizard_* Templates
Should just need these two, generated from XI 5.4.5 but should be valid quite a ways back.
Looks like it worked, thanks!
(You may lock this thread if you want.)
