Hidding database passwords
jabi27
Post by jabi27 »
How can we hide database passwords, ex
check_xi_postgres_db!-H emdb3.stil.dk --port=5432 --dbuser=xxxx --dbname=udb --dbpass="******" --action=database_size --warning=100GB --critical=110GB
so --dbpass is not visible ?
Best and thanks
/Jan
Re: Hidding database passwords
Post by mcapra »
You might find this documentation helpful:
https://assets.nagios.com/downloads/nag ... ponent.pdf
Basically, you can define sensitive information (like database credentials) in the User Macros Component if you're using a recent version of Nagios XI. This would remove some (but not all) visibility from the Nagios XI GUI.
Thanks @mcapra for the help.
