service monitoring in dual fail over servers
Hello Team ,
I have situation here that i want to monitor set of services for monitoring an application in HostA or HostB . Host A and B are kind of fail over environment , i mean the application will be running at any one of the host at a time . Application will be switched to other server automatically when the currentserver is down .
Is there any idea to have both the server IP for a single host and then we can have all the services mapped to this new comman host .
Service should check the host which have the application up .
Re: service monitoring in dual fail over servers
Can you please provide more information, ie: what OS? What application? What mechanism for "failing over" to HostB? and what version of Nagios Core?
Thank you!
Thank you!
You could use the plugin called check_multi and it could be configured to generate an alert when both of the services are down on both hosts if that is what you are looking for.
https://exchange.nagios.org/directory/P ... ti/details
Take a look at it and see if this is what you are looking for.
Else, you can search that site for another plugin.
Sorry for delay in repond .
The above link provided explains about the chek..but the download URL is not working . i think this check is been removed .
Here's the github page for check_multi in case the previous website isn't working for you:
https://github.com/flackem/check_multi
- Pitone_Maledetto
you could use custom macros.
I have this setup so I can check the ILO and the host in the same host configuration.
host_address ip_of_server_A
_serverB_ip ip_of_server_B
You need to configure the service and commands to suite this configuration but works pretty good.
If you reckon that this is a good solution for you I could provide some configuration examples.
Regards
Sent from the mobile client - Forum Talker
Regards
"It is impossible to work in information technology without also engaging in social engineering"
Jaron Lanier
Jaron Lanier
Thanks for the assist, @Pitone_Maledetto!
- Pitone_Maledetto
@tmcdonald you are welcome
just an example of how I would roughly make it work.
Command definition
Host definition
Service definition
Command definition
# 'check_load_ssh'
command_name check_serverB_load
command_line $USER1$/check_by_ssh -H $_HOSTBADDRESS$ -l your_log_name -C "/usr/lib/nagios/plugins/check_load -w $ARG1$ -c $ARG2$"
use generic-host
host_name serverA
alias serverA and serverB
hostgroups your_hostgroup
address serverA_ip
_BADDRESS serverB_ip
# LOAD CHECK
name serverB_Load
service_description serverB Load
check_command check_serverB_load!7.2,5.6,4.8!8,6.4,5.6
normal_check_interval 5
notification_interval 10
notification_options w,c,r
Jaron Lanier
Jaron Lanier
- tacolover101
as another side note, why not assign a VIP between your active / passive services and then monitor the VIP?
- Former Nagios Staff
@padu_3891, did you have any other questions or are we ready to lock this up?
