Hi All,
I am new to Nagios and have downloaded nagios XI on my system. As per manual installation process changed through command prompt changed to the dir /tmp/nagiosxi and when try to run command fullinstall got the message "fullinstall is not a recognized command". Is the Linux is required to have on the system for the nagios application. Please help me, i am not able to install it successfully.
Is is it necessary to have Linux on system for Nagios XI ins
Re: Is is it necessary to have Linux on system for Nagios XI
Yes, you need Linux to run Nagios XI.
Nagios XI is currently supported with the following Linux distributions for both 32 and 64 bit installations:
CentOS 5 / 6
RHEL 5 / 6
Please, let us know if you have any more questions.
Thank you!
CentOS 5 / 6
RHEL 5 / 6
Thank you!
Additionally, you can run Nagios XI in VMware Player on a Windows machine
We have this documented this here
http://assets.nagios.com/downloads/nagi ... _Notes.pdf
You can download our VMware Virtual Machine here
http://library.nagios.com/library/produ ... ain#vmware
Hope this helps
Hope this helps
