How to use MSSQL Database Config Wizard ?
sac1472
Post by sac1472 »
I want to monitor mssql databse using MSSQL Database Config Wizard but unable find any tutorial for same.
So,Please share any doc on MSSQL Database Config Wizard and MSSQL Config Wizard.
What Pre-requisites required on nagiosxi server?
What type permissions/access/authentication required on MSSQL server ?
If possible, guide me to configure monitoring using MSSQL Database Config Wizard.
Thanks in advance!!!!!!!
Re: How to use MSSQL Database Config Wizard ?
Post by mcapra »
Here's the documentation for setting up the prerequisites:
As for authentication, the default MSSQL wizards require that you use SQL Server authentication.
Post by dwhitfield »
Thanks @mcapra!
OP, please let us know if you need additional information.
sac1472
Post by sac1472 »
Thanks for that document @mcapra!!!!!!!!
Is there any configuration need to be done on windows Server like nsclient ? If yes, Please guide me to do that.
Thanks in advance !!!!!!!!!
sac1472 wrote: Is there any configuration need to be done on windows Server like nsclient ? If yes, Please guide me to do that.
If you are talking about monitoring other things than MSSQL, then you should start a new thread.
As for the authentication method, that question was already answered by @mcapra: SQL Server authentication.
