Nagios Core UI not displaying intermitently while refreshing
vnoc
Post by vnoc »
Hi All,
I have installed Nagios Core in one of the machine and whenever i am trying to browse the UI most of the time the added servers are not getting displayed.Can anyone please help me in fixing this
Re: Nagios Core UI not displaying intermitently while refres
Can you post the nagios.log file from that system as well as the output of these commands run as root?
ps -ef --cols=300
uname -a
cat /etc/*release*
vnoc
Post by vnoc »
Thanks for your response
Please find the attachment of executed commands.
I didn't find any nagios.logs file could you please guide me how to create a file
Executedcommands.txt
(11.32 KiB) Downloaded 389 times
In the output of the ps command, it shows that there are multiple copies of the Nagios processes running and that would cause the issue you are seeing.
To fix this, login as root to the Nagios server and run the following commands.
service nagios stop
killall -9 nagios
service nagios start
vnoc
Post by vnoc »
Thank you very munch .
After executing the shared commands the issue is fixed .
bolson
Post by bolson »
Closing topic as resolved.
Thank you for using the Nagios Support Forum.
